Ground Loop Hum
Polkitup2
Polkitup2 Posts: 1,641
edited March 2010 in Electronics
I added a separate amp to my system and now I have a 60 hz hum. The hum disappers completey if I disconnect the front speaker pre-outs from my receiver to the HT bypass inputs on my pre-amp. I tried numerous different scenarios using different circuits, trying everything on the same dedicated circuit, different cables, unplugging everything, cheater plug, etc. Depending on what I did, I could increase the hum or lower the hum but never get rid of it entirely unless I either unplugged the RCA cable from my reciever to the HT bypass input on the pre-amp, or used a cheater plug on the new amp. Doing either of these would give me dead silence but of course I would like to use the HT bypass and I am not sure it's safe to run the amp with a cheater plug. I guess I was somewhat surprised that when I had all components connected to one power center on one dedicated circuit I still got a slight hum. Any ideas on how to fix this?
Post edited by Polkitup2 on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2010
    The hum is more than likely related to a video source. Start disconnecting them one by one, Satellite, cable, playstation, etc to see where the issue(s) are.
    Cheers,
    Russ
  • dpowell
    dpowell Posts: 3,081
    edited March 2010
    Try unplugging the coax cable from your cable TV box and see if it clears up. If so, you may need to grab a Jensen ISO-MAX VRD-1FF. Did the trick for my system.
  • Polkitup2
    edited March 2010
    Yep, I forgot that I had the cable feed running through the power center. I disconnected it and 99% of the hum went away. So now now I can either not have cable, not be able to use HT bypass, or run with a cheater plug on my amp :D
  • Polkitup2
    edited March 2010
    Good idea on the Jensen, that's sounds like my best option. Thanks guys!
  • dpowell
    edited March 2010
    No prob. Don't know if you use Bing Cashback but I found a new Jensen on Ebay for around $45 plus a few bucks for shipping and used Bing to get 8% cashback.
    Here's the listing I bought from. No affiliation.
    http://cgi.ebay.com/CABLE-TV-GROUND-LOOP-ISOLATOR-JENSEN-ISO-MAX-VRD-1FF_W0QQitemZ380190677882QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5885215b7a
    BTW, he has best offer but I made 3 offers and they were all automatically rejected. My highest offer was $40 and at that point, I got more savings from using Buy It now with the cashback.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2010
    Just to add to the above suggestions, I've had ground loop issues in the past that were resolved with better ICs all around. This is especially true of using a step-up transformer in the turntable path. Although this wasn't so much a ground loop hum it was a 60 cycle hum and I was able to eliminate it using MIT Shotgun S3s and with Joe Abrams' suggestion of twisting 8 twists into the pair really got rid of the hum.
  • phipiper10
    phipiper10 Posts: 961
    edited March 2010
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
