Polyurethane on Monitor vaneer?
polkfan38
polkfan38 Posts: 360
edited March 2010 in Speakers
Was wondering if anyone has put poly on their Monitor speakers? Or any other line? I would like to give them a nice polished look.
Things are more like they are now than they ever will be!
Post edited by polkfan38 on
    F1nut Posts: 51,794
    edited March 2010
    You don't get a nice polished look by simply applying a finish, especially a poly finish. The nice polished look is the result of the hard work it takes to properly rub out the finish.
  • halo71
    halo71 Posts: 4,632
    edited March 2010
    I used wipe on poly on my Monitor 10's. Took 1000 grit sandpaper and lightly sanded. Wiped the cabinets down, applied one coat of poly. Used 000 steel wool. Applied 2nd coat. Looks much better now. The wipe on poly leaves no swirl marks and dries in about 30 minutes. I have also brushed it on wood before with excellent results.
    Keep in mind this will not give you a nice polished piano finish. But still looks very nice.
    --Gary--
  • polkfan38
    edited March 2010
    Darn. I was hoping for that "piano" finish. I think I will still try it though. Halo71, should I assume you used "gloss" poly?
  • halo71
    halo71 Posts: 4,632
    edited March 2010
    Yes. Minwax wipe on poly clear gloss.
    --Gary--
  • polkfan38
    edited March 2010
    Cool. Thanks!
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited March 2010
    I am curious. Have you decided what to use and how to go about finishing your monitors?
    F1nut Posts: 51,794
    edited March 2010
    Before folks start whipping out the poly.....applying polyurethane over an exsisting finish is not a good idea.
  • polkfan38
    edited March 2010
    I am guessing it will not adhere very well. it might start flaking off after awile. I am still researching how to go about this. I know a pro wood worker and I will see what he thinks.
    F1nut Posts: 51,794
    edited March 2010
    I am a pro.
  • polkfan38
    edited March 2010
    I have not done this work before. Maybe I ought to leave them alone. I don't want to screw them up!
