Speaker Placement ? W/PICS
Agent
Agent Posts: 65
edited March 2010 in Speakers
I have a rather large living room and with the way the ceilings work, along with the opening in the back it is probably an acoustic mess. My question has to do with the front speaker placement. From my center speaker it is about 16ft to the listening position. Quite a long ways indeed. How far apart should I put my fronts. I have read the triangle placement but that won't work because of how far back my couch is. Should they be closer, farther apart, straight, toed in, etc. I have included some pictures to help you get an idea of what my room is like. We just bought this house a few months ago so the walls are still a little bare. The speakers are RTiA7s, CSi5, PC12-NSD.
From the seating position
Standing in front of TV..Ignore the dumb placement of surround, waiting on upgrade so I haven't mounted them yet.
Standing in corner by sub...view of hallway
Standing at edge of hallway
The speakers are currently toed in to point toward the middle of the couch. Also in the picture is XPA-3 and Pioneer VSX-9040TXH and Samsung LN52A650. Thanks.
Samsung LN52A650 : PS3 : RTi A7s : CSi5 : SVS PC12-NSD : Pioneer VSX-9040THX : Emotiva XPA-3 = :D
Post edited by Agent on
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited March 2010
    Beautiful! Nice setup, room, everything! Amp looks good too. ;) I'll have to look closer at your pics later to give you some more feedback. They're not displaying so nicely on the iPhone...
  • krauley
    krauley Posts: 81
    edited March 2010
    nice setup! imho i would move the couch away from the back wall some bringing your sitting position inline to keep your fronts where they are. that would give you room behind the couch for stands if thats what you were thinking or... wall mounts which would aim the backs right at you :). seems like the area behind the couch is dead space anyway and if you moved it up to almost even with the doorway you could put somekind of shelves or something to make better use. I think you are sitting too far from the tv @ 16 feet. well you asked :D
    Onkyo 808
    Emotiva XPA-5
    Polk Audio M70s fronts
    Polk Audio Cs1 center
    Polk Audio 50s surrounds
    Polk Audio 30s backs
    Polk Audio Psw505 sub
    Polk Audio Psw10 sub
    Oppo BDP-93
    PS3 slim 250gb
    Vizio 55" Led-lcd
    HTPC Evga P55/Intel i7-860/Evga 260 Sli
  • cnoat
    cnoat Posts: 315
    edited March 2010
    With your couch so far back I wouldn't trianglate the fronts.Play with them until you get the best sound.
    Nice Setup
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • Agent
    Agent Posts: 65
    edited March 2010
    krauley wrote: »
    No your right, I did ask, and I appreciate the advice. That sectional couch is huge, but very comfortable. I have honestly thought about moving it forward but if I do, I would probably have to take a piece out and put it somewhere else. Every piece comes apart and they all kick back. That part behind the couch is like one of those windowsill bench seats that lift up to store stuff under. Hmmm decisions. So you wouldn't recommend going any closer together with the fronts eh? Well, I have the next week off so I will have some time to tinker with things. Could you explain exactly what you were talking about with the shelves, I'm all ears. Keep the suggestions coming, I enjoy everyones input.
  • mdaudioguy
    edited March 2010
    Oh, wow, that IS a tough surround speaker situation. I can see where you might not want to move the sectional forward, because it's wall to wall. Looks nice and comfy too! Another idea - I know you were thinking FXi, but have you considered an in-wall/in-ceiling option? Maybe you could mount some in the angled part? My son just looked at it and said the same thing!
  • Agent
    Agent Posts: 65
    edited March 2010
    mdaudioguy wrote: »
    I would definitely consider it if I could somehow hide the speaker cables coming down. I hate seeing cables if at all possible. If I mounted them just over the couch so the couch would conceal them they would probably be too close. How could I mount a speaker, flush with the wall, on an angle like that? I was planning on mounting the fxi's on the side walls but I wonder how that angle would affect the sound?
  • mdaudioguy
    edited March 2010
    You could definitely run the wires into the wall near the bottom and fish them up. It requires a little patience and effort (and joint compound and paint), but I'd consider doing something like that. If mounting speakers on the sides, the problem to me seems to be that the higher you place them, the farther forward they'll have to be - almost in front of your seating position.
  • Agent
    Agent Posts: 65
    edited March 2010
    Well, it doesn't look like it in the picture but there is room to mount an xfi3 on the "side" just above the top of the couch in the far right corner, and then match it on the left. It would be exactly aligned with my ears at the seating position. Now if I wanted to do 7.1, that would be a little tricky and I would probably have to do something like you suggested. I may just play around with pulling the couch out some or take a section out. I don't know, I like how it wraps around the room and would hate to break it up into two section couches. I don't know if the wifey would even go for it.
  • mewisemagic
    mewisemagic Posts: 194
    edited March 2010
    have you tried reversing your setup? system where the sofa is,and sofa behind the three windows? just a thought
  • mdaudioguy
    edited March 2010
    Or that might work... Also, I see no benefit at all of 7.1 in that room layout.
  • Agent
    Agent Posts: 65
    edited March 2010
    I have considered this but that opening in the back is off center to the left quite a bit. In order to look good, I would have to center the television there and by doing so would put it too far to the left. By the time I center the tv and put the A7s around it one A7 would have to be almost touching the wall while the other would be aways away. Wouldn't look good imo, maybe I'm just picky. Don't get me wrong, it sounds pretty darn good where it is, however, like most of you, I just wonder how much better it can be.
  • krauley
    krauley Posts: 81
    edited March 2010
    i think he means to put the equipment centered to the room and not to the window, at least thats what i was thinking when i read it. youve got that week to try it ;)
    Onkyo 808
    Emotiva XPA-5
    Oppo BDP-93
    PS3 slim 250gb
    Vizio 55" Led-lcd
