How does it do that?
polkfan38
polkfan38 Posts: 360
edited March 2010 in Electronics
After playing with my Denon AVR 1802, I have it set to "PLII" for watcing TV. It is hooked up to my cable box with just the two audio outs. It is getting surround on some channels. How is surround info transfered through just two "left and right" outputs? I am baffled!
Things are more like they are now than they ever will be!
Post edited by polkfan38 on
    heiney9 Posts: 25,504
    edited March 2010
    It a digital algorithum built into a decoding chip. It's fake, as in that info isn't really in the original signal content. That technology has been around since the advent of Surround Sound in the late 80's early 90's.
  • danger boy
    danger boy Posts: 15,722
    edited March 2010
    it's taking your two channel stereo signal and processing it to be DPLII surround sound.
    some times it doesn't sound to bad... and often times beats listening to just the front left and rights
    PolkFest 2012, who's going>?
  • polkfan38
    edited March 2010
    Interesting. I can call and ask but, is true surround broadcast through cable? We will be upgrading to a "HD" box this summer.
    Yes, Danger Boy. It is much more fun than 2 channel TV!
  • concealer404
    concealer404 Posts: 7,440
    edited March 2010
    polkfan38 wrote: »
    Depends on the channel... I'm pretty sure some of my movie channels do.
  • vc69
    vc69 Posts: 2,500
    edited March 2010
    Digital cable systems usually transmit basic channels in stereo. The HD and digital tier channels are dolby 2.0 or 5.1 depending on the source and bandwidth allotted for the channel.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • danger boy
    edited March 2010
    depends on the channel and the program material.
    not all programs are dolby digital 5.1
    most HD channels I've found are broadcast in 5.1 surround.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited March 2010
    Dolby surround has been around since the early-mid 80's and prologic came out in the mid-late 80's(addition of the center channel). Basicly the decoder take the right and left input puts and separates them based on differences. Left only info from the left front, right only info on the right. Center is derived from the like signals in the left and right channels and the surrounds(which was a frequency limited mono channel with 2 speakers) information comes from the difference in the left and right channel. I not sure how well I remember this, but I'm pretty sure it's pretty close.
  • polkfan38
    edited March 2010
    That is cool stuff! I kind of wish I got into this earlier! I have a 7-8 year old DVD player hooked up with a digital coax line. If I play a movie that was recorded in 5.1, does the same principal apply or is that 5 actual descrete channels coming through the single line?
  • dudeinaroom
    edited March 2010
    It's is actually 6 discrete channels. Your left, right ,center rear right, rear left, and LFE(sub).
  • polkfan38
    edited March 2010
    Awesome! Thanks!
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited March 2010
    heiney9 wrote: »
    I don't think it's necessarily fake. Dolby Surround, now known as Dolby Pro Logic, is a true multichannel format in its own right, albeit analog. PL can take any 2-channel stereo signal and make it sound surround-like, however, movies with a Dolby Surround or Dolby PL encoded 2-channel soundtrack will be output by a PL decoder in a 4.0 format, essentially as described above. Send the lower frequencies to a sub, ignore the fact that both surround channels are the same, and you have virtual (fake) 5.1! :);)
    We've download several movies via PS3 in SD and the 2-channel soundtracks sound pretty good with PLIIx or DTS Neo:6 (DTS's version of PL).
  • polkfan38
    edited March 2010
    On a side note, I know someone who is in the film industry who has won a Grammy for sound mixing. All movies are mixed in 5.1 with only one or two exceptions where he did some in 6.1. My only point to mentioning this is that 7.1 (or beyond) IS fake. Just processed by a reciever.
    The PL stuff is neat though!
  • polkfan38
    edited March 2010
    My bad. I meant Oscar. Not Grammy.
