Looking for some grill cleaning advice
DaveHo
DaveHo Posts: 3,583
edited March 2010 in Vintage Speakers
The RTA-12C's I picked up a few weeks back were absolutely filthy. The guy I bought them from was using them for music in a house he was renovating. The top hat grills were caked with drywall dust, etc. I've already vac'd them & blown them with compressed air, but they still look horrible. The material itself is in fine shape, & due to the complexity of wrapping them I'd rather clean them than try replacing the fabric. Does anyone have some suggestions? I've thought about using a mild detergent & just hosing them off, but I'm worrried about what would happen to the particle boad that makes up parts of the frame. Anyone think I can get away with it if I'm careful & dry it quickly? Any other ideas?
Thanks.
-Dave
Post edited by DaveHo on
  • danger boy
    danger boy Posts: 15,722
    edited March 2010
    oh I thought this thread was about cleaning your bbq grill :p
    PolkFest 2012, who's going>?
  • DaveHo
    DaveHo Posts: 3,583
    edited March 2010
    Oddly enough I usually use the shop vac for that too. At least as a first step to get the chunks. :D
  • gdb
    gdb Posts: 6,012
    edited March 2010
    If your shop vac has wet capabilities.......quickly wet an area of grille cloth with some Rug Doctor upholstery cleaner solution and immediately extract it with your wet vac. Works great, and doesn't make things too wet for too long. Point a fan at the grille afterwards for complete drying. Good as new !!;)
  • skrol
    skrol Posts: 3,462
    edited March 2010
    Try one of those sticky paper roller thingies for removing lint and animal hair from clothing. They get mine looking like new.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Zeros
    Zeros Posts: 940
    edited March 2010
    skrol wrote: »
    AKA a lint brush
  • skrol
    skrol Posts: 3,462
    edited March 2010
    That's it. I really shouldn't try to think after I've taken Imitrex.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jimmydep
    jimmydep Posts: 1,305
    edited March 2010
    If you don't have a lint brush, duct tape works just as well.
  • DaveHo
    DaveHo Posts: 3,583
    edited March 2010
    I forgot to mention it, but I did use the lint roller as well. No dice. It's really caked in there. I'll give the shop vac extraction method a try. We also have a carpet shampoo'er with a hand attachment. I'll have to see if I can maybe use that also.
    Thanks.
    F1nut Posts: 52,000
    edited March 2010
    Resolve Fabric Cleaner.
  • HB27
    HB27 Posts: 1,518
    edited March 2010
    I use Woolite foam upholstery cleaner on my grills with the fibreboard frames. ($1 a can at the local dollar store))
    It doesn't get the fibreboard damp enough to warp or disentegrate the frames and does a great job on the cloth. It's never faded or changed the cloth in any way.
    I spray it on, sponge it around lightly, let dry, and vacuum with a shop vac.
    For pet stains use the Woolite. I used to have a dog in the house
    My plastic frame grills I just make up a mixture of laundry detergent, windex, and water in a spray windex bottle. I wet them down thoroughly and use the shower massage to rinse with luke warm water.
    I've used hot water before and actually released the glue from the frames.
    Harry
  • dl090465
    dl090465 Posts: 212
    edited March 2010
    2 inch masking tape works well, not ad much adhesive as duct tape so it wont stick to your grills, but gets the job done....
    Room 1:
    ONKYO TX-SR608
    Polk Complete RT 5000 System
    Polk RT3000p's Front
    Polk CS1000p Center
    Polk FX 1000's Rear
    Room 2:
    ONKYO TX-SR608
    Polk RT2000's Front Someone Please Sell Me Some RT3000 so I can have a second RT5000 setup !!!!
    Polk CS1000p Center
    Polk FX1000's Rear
    Polk PSW 120 front
    Polk PSW 505 rear
  • zarrdoss
    zarrdoss Posts: 2,562
    edited March 2010
    with plastic frame grills its easy, just throw them in the shower. these wood frame grills can be tricky. usually a good steam cleaner will do the trick. but sometimes you just have to replace the material as it will not come clean.
  • Zeros
    Zeros Posts: 940
    edited March 2010
    How about a picture to see how bad they really are? You know we all love looking at pictures.
  • smcgov34
    smcgov34 Posts: 46
    edited March 2010
    there's some cleaner, can't remember the name but it's in the automotive section at Wal Mart and it's a foam with a brush on top of the can and it's red. i would try that, it's not going to soak your stuff, but get it damp enough for the foam to work with some light scrubbing.
  • DaveHo
    DaveHo Posts: 3,583
    edited March 2010
    Yes, they really do look that white. It's not the flash..
  • tx_polkhead
    tx_polkhead Posts: 248
    edited March 2010
    Wow those are a mess! I think you are going to need more than tape and lint brush to get them clean. I just looked at my top hats and that's a whole lot of mostly uncoated particle board, so I understand the worry about getting it wet. How about getting two sponges damp with the cleaning products mentioned here and pressing the sponges from top and bottom to soak the fabric? When I purchased mine a few years ago the house I picked them up from was less than tidy, but the stereo gear inside was all tip top, so the polks were in good condition, but when the door opened up and I saw the state of the house I was a bit concerned, how about another comma, as I ramble on... Good Luck!
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
  • zarrdoss
    edited March 2010
    steam cleaner or gently take them off and wash them let dry and re-glue on. those are gross!
  • BrettT1
    BrettT1 Posts: 560
    edited March 2010
    Thinking new grille cloth.
