New member to KT88/6550 family
doctorcilantro
doctorcilantro Posts: 2,028
edited March 2010 in The Clubhouse
Just got word on this new tube: Tung-Sol KT120:
http://www.newsensor.com/releases/KT120TungSol.pdf
In September of 1950 Tung-Sol introduced the 5881, an uprated and industrial version of the 6L6GA with a 23.5 watt plate dissipation, opening the doors to the hi-fi movement of the 1950s. This rugged tube also found a home in the '59 Fender Bassman and servo amplifiers used in B-52 bombers. In 1955 Tung-Sol raised the bar of high fidelity with the introduction of the 35 watt 6550, which could deliver 100 watts with a pair in push-pull configuration. This tube was used in the Dynaco Mark III and Sunn amplifers.
New Sensor now announces the Tung-Sol KT120, which has a plate dissipation of 60 watts, making it the most powerful tube in the 6550/KT88/KT90 family. A pair of these tubes in push-pull configuration can deliver power levels of 150 or more watts. When used at the parameters found in existing 6550/KT88/KT90 circuits, the Tung-Sol KT120 is impervious to overload, delivering peak power with extreme reliability and long tube life. However, taking advantage of the higher current handling capacity of these tubes, a very unique and super powerful and stable amp can be designed using the Tung-Sol KT-120.
dc
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Post edited by doctorcilantro on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited March 2010
    Thanks DC,
    I wonder how they would sound in a CJ MV75a-1?
    Cheers, Ken
  • sucks2beme
    sucks2beme Posts: 5,686
    edited March 2010
    So it sounds like it will drop right in, and it should be able to handle a bit
    more power in existing configurations, and make 100 WPC amps priced more in line
    with existing 50wpc amps. $$$$?
  • [Deleted User]
    edited March 2010
    Hello DC,
    There doesn't seem to be anything on their web site. I wonder when they will become available?
    Cheers, Ken
  • sucks2beme
    edited March 2010
    Hello DC,
    Cheers, Ken
    Right about 10 minutes after I re-tube the AR vt-60.
  • [Deleted User]
    edited March 2010
    Yeah, that sounds like me. I'd just about ordered a quad of EI KT90 when I saw that thread.
