Question: External Amp Question
cscsDanny
Ok, say I purchase a Adcom GFA-7605 Home Theater Power Amplifier how is this physically connected to my existing receiver? Then Im curious as to how volume is controlled? I would be running this power amp to all 5 of my existing speakers?
Thirdly, would this external amp improve music clarity and detail at lower volumes?
Receiver: Pioneer Elite VSX-43TX
DVD PLAYER: Sony DVP-NC655P
Mains: Bi-Amped Polk Rt1000i
Surrounds: Bi-Wired Polk Rt55i
Center: Bi-Wired Polk Cs400i
Subwooofer: SVS PB1
Subwooofer: SVS PB1
Post edited by cscsDanny on
rca cable from your receiver's preouts to the amp. receiver controls the volume after you use your spl meter and setup program to get everything all nice again
i use an amp to just power my front 3s for now -
your receiver has to have pre-amp outputs, not all of them have them...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
he has a sony lower line. Bubba, I dont think I need to look at specs! lol! Your going to need a new receiver probally.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
yep...out a subwoofer preout! Your next upgrade has receiver written all over it. I know how ya feel! http://www.crutchfield.com/cgi-bin/S-tedzMhkJND6/ProdView.asp?a=&s=0&cc=01&g=10420&id=features_and_specs&i=158STRE685- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
just ordered the big brother to the GFA-7605 the GFA-7607 cant wait for it to come. i made sure i got a recever with pre outs just for that reason. there is a way around it but i dont know if it will sound good.
My friend has that similar or same receiver, nothing against yours but i set it up for him and that was the pain in my side for hours.. real hard to figure out and with a fold out 2 page manual..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
drats and double dratsReceiver: Pioneer Elite VSX-43TX
Subwooofer: SVS PB1 -
Those are inputs, your receiver shows only one pre out, for the sub.
Take a look at the other sony's, they show in's and then there's the pre outs to use an external amp with. -
like the guys here said.. you must have preouts on your receiver to use an external amp like the Adcom you are looking at.
Volume is controlled the way it is now. from your receivers volume control knob. none of that will change when you ad an external amp.
Yes would need to make sure the external amp you buy is 5 channel amp. there are 2, 3, 4, 5, and 7 channel amps. The more channels. the more expensive.. and the more watts per channel too.
External amps will usually add some clarity to your receiver when added.
good luck dude, come back here if you have more ?'s
AlPolkFest 2012, who's going>?
