My 8's sound better than my 12's
Any help is much appreciated.
I am running a pair og rti12's off of an onkyo 898 110 per channel.
My rti8's sound better.
I am getting plenty of movement with the 12's.Do I need more power.
They the 12's just soun muffled.
Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC
Sub SVS Ultra Tv 12
AQ T4 SC
Post edited by cnoat on
Put an amp on your 12's, or maybe the tweeters are out on your 12's.
Welcome to club Polk.
Ben -
Thanks for the input.I kinda figured I probably need more power.The tweeter seems to be ok.Any suggestions on 2 channel amps.Parasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
Do you have them wired in phase.
Yes they are in phase.Parasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
Thanks for the advice.I am going to order a 200 watt a channel amp right now.I think I am going to go with an adcom.Any feedback?And again thanks.It is nice to have some place to talk audio.Parasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
I really enjoy my Rotel DClass amps with my RTi12's. This includes the 1085 or the 1091's. Also, how small is your room? What is placement in the room like? 12's need a lot of room to breathe when you get them moving. If I remember right I have heard RTi8's are bright so it might be what you are used to listening to.
I really like the parasound amps, rotel, outlaw (for budget), and a few others. The pro series amps are supposed to be nice but I haven't had a listen.
If you want more bang for the buck try the used market.RTi12 x 2
RTi6 x 4 Surrounds
CSi5 x 1 Center
Rotel RB-1091 x 2 for powering mains
Rotel RMB-1085 for power of surrounds and center
Rotel RSP-1068
Infinity ps-12 Sub
PS3/Xbox 360 as source and PC transport -
Thanks for the reply mstang,
It is not the brightness or highs they just seem to be lagging mid range.Just not as crisp as my 8's.My room is 18 by 26 with the speaker placement 10 feet in front of my seating position.I will look into the rotels,it seems to be a favorite among club polk.I really appreciate the help.
Onkyo ds 898
rti12's mains
csi5 center
rti8's surrounds
rti6's bk surroundsParasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
You need an amp to get those big boys to sing. 200wpc should suffice. I run a IceAmp on my 12s @ 525wpc, and have excellent results.Shoot the jumper.....................BALLIN.............!!!!!
thanks sherardpParasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC -
i bet those bad boys need alot of power. i mean look at them they are very intimidating:eek:front: rti8
center: csi5
surround: fxi3
sub: eD a2-300
receiver: onkyo 805
ps3 -
Keep in mind 1watt will get you around 90 db's on these speakers. yes, more power may get you more control but the quality watts are what matters more then the amount of watts.
It's all about that quality first watt for the average user. Also, I really noticed mine opened up and sounded so much more natural when I upgraded from my HTR-5760 to my RSP-1068.RTi12 x 2
RTi6 x 4 Surrounds
CSi5 x 1 Center
Rotel RSP-1068
Infinity ps-12 Sub
I have read where a lot of people said their 8s sounded better than there 12's...that is...until they fed them hungry 12s some power. That is most assuredly your problem. I have my RTi A7s powered with an XPA-3 (200w per channel) and they scream like a raped ape...no joke. My Pioneer goes from -80 to +12 and at -10 its like being in the front row of an AC/DC or Metallica concert. Insane, with no distortion whatsoever. Was playing the song "One" by Metallica yesterday and with the PC12-NSD, when that drum solo toward the end kicked in, it was unbelievable. Give them some juice and step the hell back. The 8s sound better because it doesn't require as much power to bring them to life. Good luck.Samsung LN52A650 : PS3 : RTi A7s : CSi5 : SVS PC12-NSD : Pioneer VSX-9040THX : Emotiva XPA-3 =
I went from 10's to 12's and did not notice a whole lot of improvement even with my yamaha at 130w/ch. Then I hooked them up to a Carver TFM35x which is 250 watts/ch.Made a big differance! I have read numerous posts from differant forums and these speakers want to sing but they need the power for them to shine. And they were right. I cross these over at 60hz and let my two mirage subs handle the low end.
Get a good power amp.I recommend Carver myself since I feel this will tame down the brighness of the 12's. Adcom are good,just do not know how they will sound with the 12's. Have not tried Rotel but here great things about them. Remember,you want to find a amp that complements these speakers.
Get quality speaker cables!
Then get a quality interconnects between the amp and your Onkyo.
Every upgrae made a improvement in my sound!
I can tell you that this journey has made my RTi12's shine with greater midrange and highs! I am extremely happy with them.Just a suggestion. Good luck!
___________________________
Yamaha RX-V2600 AVR
Carver TFM35X Amp
Sony NC685V DVD/CD/SACD
Pioneer BD320 Blue Ray
Samsung 52” LCD
Mains Polk RTi12’s
Center Polk CSi5
Rears Infinity Alpha 25ES
Subs Mirage Omni S 10’s (2)HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
RTi8's are good speakers, under rated in my mind.Home Theater
Polk RTi8
Polk Monitor 40
Polk CSi5
Polk MicroPro 2000
Visio 42 LCD
Denon AVR 790
Samsung BD 1600
Two Channel
Polk SDA 2B -
bullsh*t!
nah just saying that cuz i got the rti12s.
Have heard several people say the 8s were the most accurate of the seriesfronts=rti12s(cherry)
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
audioquest diamondback 1m
"Maesto" straightwire cables
pangea ac-9
playstation3/120gb=blu-ray/media server
monitor=lg 55inch lcd(1080p)
TT Set-up=Pro-Ject RM 1.3
Kenwood Phono
bren1 Clamp
Herbies Slipmat
"It doesnt mean that much to me,to mean that much to you" -
Thanks all.It def sounds like I need more power.
TOOL ROCKSParasound Avc-1800
Sub SVS Ultra Tv 12
AQ T4 SC
