Rattle inside speaker
polkfan38
polkfan38 Posts: 360
edited March 2010 in Speakers
Moving my Monitor 40s around this morning, I noticed something that is bugging me. In both speakers, there seems to be something loose. It rattles around in there. If I turn the speakers upside down and then back again, it goes "tic" and then "tic" again. Does the crossover float inside them or is something afoot? With the exception of shipping, these have been babied!
Things are more like they are now than they ever will be!
Post edited by polkfan38 on
  • ken brydson
    ken brydson Posts: 9,001
    edited March 2010
    polkfan38 wrote: »
    Odd that it's both speakers. The c/o's don't "float". Pull a driver and see what it is...
  • polkfan38
    edited March 2010
    It is a fairly audible "tic" like there is a marble in there. I will open them up tonight and see what I find.
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2010
    Do you have children?
  • RyanJoz
    RyanJoz Posts: 116
    edited March 2010
    did you drop the little plastic plugs from the banana plugs in them? I did it on accident when i was trying to remove one from the a9's.......binding posts are directly over the port.
    Ryan Jozwiak
    "Because music was meant to be felt and heard"
    polkaudio RTiA9
    polkaudio RT35i
    polkaudio PSW 404
    HK 3370
    HK FL8380
    HK DVD 22
    Adcom GFA 5500
    Samsung 40" LCD 120 Hz
    tonyb Posts: 33,072
    edited March 2010
    Dead gerbil, end of story.
  • skrol
    skrol Posts: 3,448
    edited March 2010
    My Monitor 5A's both had a bunch of pieces of glue rattling around inside from when they were manufactured. Or someone could have dropped something in your ports.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • polkfan38
    edited March 2010
    OK, I pulled the bottom driver out of both my Monitor 40s. I found several things. First off, the thing rattling around in both were those light gray plugs that are used to secure the grills with! The things the grill pegs go into. LOL! Second, the white, cotton like sound deadoning material was only on the top and the bottom. The sides were totally bare! I bet filling them completely will make a difference on their sound!
  • potee
    potee Posts: 610
    edited March 2010
    Let us know.
    Paul.
  • polkfan38
    edited March 2010
    Just to get rid of some of the cabinet resonance. I hear this is a awesome fix on Infinity Primus speakers. They say to put "peel n stick" carpet pads on the inside as well. I will let you know.
  • Agent
    Agent Posts: 65
    edited March 2010
    I was going to say it is most likely some glue residue that fell off inside.
    Samsung LN52A650 : PS3 : RTi A7s : CSi5 : SVS PC12-NSD : Pioneer VSX-9040THX : Emotiva XPA-3 = :D
  • polkfan38
    edited March 2010
    I didn't find any glue residue.
