Pioneer turntable on CL, any good?
domflane
domflane Posts: 653
edited March 2010 in 2 Channel Audio
http://spacecoast.craigslist.org/ele/1659303575.html
I'm still on the hunt for a new TT, and I stumbled upon this. The description is kinda wierd, but it seems legit. What do you guys think, worth picking up or should I hold out for a Technics SL-1200?
I've seen some of the 1200's for sale, but they're a bit out of my budget so far. Thanks as always,
Dominic
RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
Post edited by domflane on
  • ozzy21236
    ozzy21236 Posts: 100
    edited March 2010
    I'd hold out for a 1200.
    Russ
    Technics SL1210mkll / AT125LC / Cambridge Audio 640P / Yamaha TX-950 / Onkyo TA-2600 / Yamaha C-80 pre/Adcom GFA 545 / Polk Audio Monitor 12 Series 2
  • TroyD
    TroyD Posts: 13,124
    edited March 2010
    Unless you know something about turntables and how to set them up....you can buy new (Pro-ject, Music Hall, Rega) for a very attractive price, plus they are plug and play. Buying a used turntable is probably the biggest crapshoot of them all.
    BDT
  • shack
    shack Posts: 11,154
    edited March 2010
    BDT
    Troy has hit the nail on the head. Great deals can be had with used TTs...but unless you know what you are doing it can be a total waste of money, time and effort.
  • domflane
    domflane Posts: 653
    edited March 2010
    TroyD wrote: »
    I've definately learned that, but even though I'm still new to all this, its fun to get older gear to tinker with. I tore my Audio Technica table apart trying to make it work with some decent success. Plus, if I botch something up, I always have you guys to help me put it back together. New is intriguing though, I'll definately look into it. Thanks,
    Dom
