Question for Rotel RSX/RSP owners
tryrrthg
tryrrthg Posts: 1,896
edited May 2003 in Electronics
I'm researching the RSP1066 or the RSX1055 and am wondering a few things about the bass managment... Let me know if I'm understanding it correctly.
If I wanted to used analog cables between my CDP and the RSP/RSX I would NOT be able use a subwoofer? The processor would automatically run a full range signal to my mains even through they are set to small.
If I use the digital input on the RSP/RSX and use the DAC's in the processor then I can use the sub?
Am I missing something... I'm getting this info from this:
http://www.rotel.com/support/faqs/faqs-rsx1055.htm
http://www.rotel.com/support/faqs/faqs-rsp1066.htm
thanks for any help!
Post edited by tryrrthg on
  • jltrdavis
    jltrdavis Posts: 78
    edited May 2003
    tryrrthg,
    Surf on over to http://www.htguide.com/ and search the club Rotel Forum. You'll find the answer your looking for.
    -Jason
  • TonyPTX
    TonyPTX Posts: 545
    edited May 2003
    There is a known Bass Management issue but it only involves the use of the 5.1 Multi-Channel input to the RSX-1055/RSP-1066, not the CD player (unless you hook up your CD player to your multi-channel input which is crazy to start off with)....
    The problem with the BM is that the Rotel sends a full signal to all drivers making the bass sound overly powerfull or just out of whack. There is a fix however which requires removing two resistors, which you can either get Rotel to do it for you before you purchase a new unit or you can do it yourself w/o voiding your warranty (assuming you don't break anything else while you're at it).
    Tony
    Damn....8 lines...I've gotta put my sig on a diet now....
  • tryrrthg
    edited May 2003
    Thanks guys! I'll keep reading to find out some more on the issue.
    For music I will only be using 2 channels. I'm not a big fan of the multi channel music.
    Thanks!
