Just bought a pair of ml source, now I need.....
polkfarmboy
polkfarmboy Posts: 5,703
edited March 2010 in Speakers
After listening to ML source and vistas this weekend I decided to buy a pair of martin logan source because I didn't think the vistas were worth the extra money . I heard them in a 7.1 motif /fresco config and did not really think there was a huge diff with vistas for movies
My question would be what receiver should I buy because I have an onkyo 606 that I will be running them with when they get here tomorrow
Post edited by polkfarmboy on
  • Huck344
    Huck344 Posts: 453
    edited March 2010
  • Huck344
    Huck344 Posts: 453
    edited March 2010
    By the way, you may want to go to the ML owners lounge. They will probably have some good advice as to what would be a good AVR for those.
  • polkfarmboy
    edited March 2010
    ML owners all have separate processor and amp combos but the source can be driven by any receiver . One guy drives his with a yamaha 665
    I think most polkies are more knowledgeable with avr's than others . I will shell out about $800 for something that has a good processor because I can add an amp later
  • Huck344
    Huck344 Posts: 453
    edited March 2010
    If you like Onkyo, upgrade to the TX-NR807 which go for around $800. In a store a month or so ago, I heard a Marantz 5004 running ML speakers. I honestly don't remember which model of ML speakers they were. But, they sounded good.
    If you can afford a bit more, I've heard lots of good things about the Pioneer SC-25. But that is about $200 more than your price limit.
    If I remember well, your focus is on HT. I assume you are sending signals via HDMI. I would recommend whichever AVR you get, has enough HDMI inputs to accommodate your various sources (Satellite/Cable, Blu Ray, PS3, etc.). I would recommend at least four inputs or else you will be stuck getting a HDMI switcher.
  • Menasor
    Menasor Posts: 283
    edited March 2010
    I thought your wife said that your old Polks sounded better than the Source? Did you have a chance to listen to any other speakers?
    Fronts: Energy RC-70
    Center: Energy RC-LCR
    Surrounds: Energy Veritas 1.0CM
    Subwoofer: SVS PC12-NSD
    Receiver: Onkyo TX-SR705
    Amplifier: Denon POA-2200 w/ Ben's ICs
    Pics of my setup (click me)
