Would a DSW4000 Be Overkill for the Set-Up i Have
Larryjepson
Hello i am wondering if a DSW4000 would be Overkill for the speakers & receiver i already own.I have had Polk speakers for a while & i want to add a Subwoofer to the mix.I own a Pair Of RT800I's front speaker i also own a Pair of RT600i's for the rear Speaker & my Center channel speaker is a CS400I.So i am looking to add a Subwoofer for both music & for Movies since i watch & listen to both alot.I was originally looking at the PSW650,505 ,or PSW1000.But some guys suggested the DSW series.Like maybe the DSW600 well i was thinking what about the DSW4000.Let me know any info will be very helpful.
Post edited by Larryjepson on
The Receiver i also own is A Sony STR-DE985 100 Watts x 6
Overkill on a good subwoofer? I think not.
If you can afford the 4000 get it, but if your going to spend that kind of money don't limit yourself to just a Polk subwoofer.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s
