~$300 or so to spend...
mdaudioguy
mdaudioguy Posts: 5,164
edited October 2012 in 2 Channel Audio
It's not much money, I know, but I have a budget of about $300 (ok, maybe $350) to spend on an amp for my new pair of LSi7s. Don't say Emo - I just sold mine mainly to free up cash for a small 2-channel music rig. I'm running them temporarily with my Adcom, and it's nice, but I'm looking for something a little different, maybe a tad warmer. Maybe a pre/amp combo, maybe just an amp, maybe an integrated. All I want to do is connect my squeezebox receiver to whatever I get. Ideas? What has sounded good with your LSis? :)
Post edited by mdaudioguy on
    nooshinjohn Posts: 26,001
    edited March 2010
    Carver TFM-35... Warm sounding little amp.
    heiney9 Posts: 25,504
    edited March 2010
    What are you running for a pre?
  • dkg999
    dkg999 Posts: 5,647
    edited March 2010
    Used Cambridge Audio 640 integrated
    DKG999
  • mdaudioguy
    edited March 2010
    heiney9 wrote: »
    Right now it's just connected through my AVR, but I intend to separate into two systems. I'm was thinking about connecting the squeezebox directly to an amp, but I understand the results will probably be better running through a pre or an integrated amp.
  • mdaudioguy
    edited March 2010
    dkg999 wrote: »
    I will add these to my watchlist. Thanks! I am seeing a few things out there in my price range. :)
  • Timothy Smith
    Timothy Smith Posts: 764
    edited March 2010
    Hi,
    If you are interested, I have a Carver TFM-35 that I am not using that I would sell for $300.
    Would you like me to see what shipping would be from WI to MD?
    Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
    edited March 2010
    dkg999 wrote: »
    +1 that is a nice piece that would solve all of your problems for now and give you something a little different than your current sound/setup.
    cnh
    edited March 2010
    mdaudioguy wrote: »
    By quite a lot. I'd recommend a nice integrated like the Cambridge or NAD, etc. A nice Adcom GFA 535 amp and lower cost pre-amp would do nicely too. If you really watch you can get both for about $300, but really an integrated is just as good and simpler.
    http://www.audiogon.com/cgi-bin/cls.pl?intatran&1274394164&/Onkyo-A-9555
    http://www.audiogon.com/cgi-bin/cls.pl?intatran&1274297438&/Cambridge-Audio-640-A--version-2
    http://www.audiogon.com/cgi-bin/cls.pl?intatran&1273855956&/NAD-C-325-BEE
    http://www.audiogon.com/cgi-bin/cls.pl?intatran&1273771886&/Arcam-Alpha-9-Integrated
    http://www.audiogon.com/cgi-bin/cls.pl?intatran&1273385167&/NAD-3020A
    The above are all excellent examples that would make your 7's sing
  • mdaudioguy
    edited March 2010
    Hi,
    Sure, but I'm going to research all of these great recommendations when I get home tonight. PM me. Thanks!
  • Pycroft
    Pycroft Posts: 1,961
    edited March 2010
    I have a Carver TCM 35x and I love it...very powerful and sounds great. The only other amp I have some experience with is B&K and I thought it had a warm sound...although, ini fairness...it's not in comparison with my current setup. I listed to a B&K ST140 powering monitor 7a's, and the Carver with SDA 1C's. I do feel they are both warm, with high quality sound.
    James
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • mdaudioguy
    edited March 2010
    heiney9 wrote: »
    Thanks H9! Some really great options there... hard to choose. I'm definitely leaning toward integrated now. Of course, the right deal on separates could tilt me back the other way. ;) Why is it I never have such luck searching audiogon myself?:o
    edited March 2010
    mdaudioguy wrote: »
    If you are going to go the route of an amp. I STRONGLY recommend a pre-amp and not using the variable output of the Squeezebox.
    For your budget this is why I recommended an integrated amp.
    The NAD 325BBE I posted a link to would be an excellent choice.
    edited March 2010
    Where can you get a Jolida hybrid integrated for $300? Please tell me, I'll be all over it.
  • coolsax
    coolsax Posts: 1,826
    edited March 2010
    along with the HK angle you can also look at HK's ebay store they sell the 3480, 3485, and 3490 which are 120wpc 8ohm and 150wpc 4ohm refurbished and if you play it right you can get one for less than $300 as well.
    I think Assimilated used the 3480 to run his Lsi 7s
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • domflane
    domflane Posts: 653
    edited March 2010
    + 1 on HK integrateds. My 3480 impresses me more everyday, it has plenty of power and lots of features that you might me interested in considering all the gear you have listed in your sig. I got mine on CL for $100 and there's plenty more on Harman's ebay store.
    That's not to say I wouldn't love a Cambridge or a Jolida Hybrid, I just couldn't beat the HK for $100.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • vc69
    vc69 Posts: 2,500
    edited March 2010
    Good suggestion. I am using one with my LS90's and it does the job pretty well. For the money, it's a fine specimen.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • mdaudioguy
    edited March 2010
  • dkg999
    dkg999 Posts: 5,647
    edited March 2010
    Good choice!
    DKG999
  • mdaudioguy
    edited March 2010
    dkg999 wrote: »
    Good choice!
    I kinda figured you'd confirm my decision. ;)
  • dkg999
    dkg999 Posts: 5,647
    edited March 2010
    Just remember, if you don't like it then it's H9's fault ;)
    DKG999
    edited March 2010
    dkg999 wrote: »
    Why not, I get blamed for other things here on CP.
  • mdaudioguy
    edited March 2010
    heiney9 wrote: »
    Yeah, saw that... Oh well, you're all right in my book! :):):):)
  • domflane
    domflane Posts: 653
    edited March 2010
    Nice choice MD, Cambridge integrateds are sweet. What did you pay for it? If you don't mind me asking . .
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited March 2010
    Congrats Ed. Looks like a nice piece.
  • mdaudioguy
    edited March 2010
    domflane wrote: »
    350 for a new Cambridge Audio 640 A version 2 integrated amp... Looking around, not too bad of a deal, I think. I'll report back once I receive it.
    This is for LSi7 2-channel. Also just ordered a HK 254 AVR for the HT rig... Lots of changes going on, all funded by selling stuff I already had! :)
  • dc55110
    dc55110 Posts: 128
    edited March 2010
    heiney9 wrote: »
    New this morning on A-gon: Jolida 1301 - $300
    (((STEREO)))
    Sony DVP-N9000es
    Squeezebox Duet
    Theta ProBasic IIIA
    Audio Research SP14
    White Audio Labs B1
    Transparent SoundWave Super
    Paradigm Studio Monitor
    B&W 802 s3
    HT
    Sony Bravia KDL-40Z4100
    Sony BDP-S350
    Yamaha HTR-5790
    NHT SB3 (Fronts)
    NHT SC2 (center)
    NHT SB2 (surround)
    Velodyne FSR12
    edited March 2010
    Yep, I see it and while I don't need it at all I am considering it, but I'm also looking at another piece.
    This just goes to show you can get a 1301 for about $300 :)
  • mdaudioguy
    edited March 2010
    heiney9 wrote: »
    Whew! Glad I didn't buy that. 30W? And look how tiny it is... :p
  • TooMal4u
    TooMal4u Posts: 11
    edited October 2012
    Hi dc55110 I have a White Audio Labs b1 amp and have no info or specs on it... do you have any specs or ratings or manual or schematics--mode of operation info? I can find very little on the web...
    Thank you very much in advance,
    David.
