RE audio vs Ascendant audio
![joker187](https://w2.vanillicon.com/20aae5833c100e023a68a225d4ae3e2a_100.png)
joker187
2 15" ascendant audio avalanch vs 2 15" re audio sex15d4...which one will pound harder ill be putting them in a 95 lincoln town car DEEP trunk. Had 2 15" orion cobalts CO15S4 and it didn't beat like you would expect two 15"s to hit im thinking it's because the trunk is so big...
Post edited by joker187 on
The enclosure is more important than the woofer. Dual 15" verses dual 15" should be a wash. Pick the ones that handle more power and give it to them. Also if you want loud go ported with a low tuning frequency...The size of the trunk realy doesn't matter..
