Polk Audio Subwoofer For Music & Home Theather
Larryjepson
First i would like to tell you what i own & then we can go from there.I am interested in buying 1 of 3 different Polk Subwoofers to add to the speakers i already own.For the Fronts i own a Pair of RT800I speakers.The Center speaker i own is a CS400I.The Rear Speakers are the RT600I's.I would like to add either the PSW650 or The PSW505 or The PSW1000.I will be listening to both Music & Movies so i would like a sub that will do both of these without any problems.I dont want to overpower the speakers i already own too.But maybe all of these will be fine.Let me know what would be the best way to go.Thanks
Post edited by Larryjepson on
oh & the receiver i own is a sony str-de985
I have DSW600 and i think it's a good sub for the price !LSI15 Front LSIC Center Lsi7 Rears Lsi7 Sides DSW600
Sony S560 Blu-Ray DVD
Sony 46W5100
Monster HTS-3600
Sunfire TGP-401 Pre
Sunfire Grand 200x7 -
+1 on the DSW series. The PSW505 is hard to beat for the price, but is mostly a HT sub. The DSW series is a much more musical sub than the PSW series, but they are a bit more costly.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Hey guys would a DSW4000 be overkill for the set up i have?Let me know Thanks
No your talking, Ive not read any reviews on it, but the PSW1000 wasn't that bad so Im guess this DSW4000 is much better. too bad tweeter is no longer around to just go in and demo the high end polk.. I miss that store.Sony KDSR70XBR2 70" RPTV
POLK LSi-25s (Front)
POLK LSi-FX (Surround)
POLK LSi-C (Center)
POLK LSi9s (Rear)
Dual JL Fathom F113 :eek: (Sub)
Onkyo TX-NR5007 (Receiver)
Oppo BDP-83 (Universal Player)
Toshiba HD-XA2 (HD-DVD/DVD)
XBOX 360 Elite -
dude, the PSW1000 is a monster and doesn't compare to the other subs you mentioned. The DSW4000 is a different story however. That thing is a beast too. No sub will be overkill for your system, IMO. The more power you have, the cleaner it will sound at all volumes. Those things come with a volume knob. Buy the best sub you can afford if you watch a lot of movies. Whats your budget? If you're looking at the DSW4000, you can get into SVS or the new Epik Empire. Check them out too. Good luckHome TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
