RT55 Tweeter replacement?
gcstokes1
Hi all
I have an opportunity to pick up some RT55 locally for decent price. I was able to test them in store, and it appears that one tweeter is out. It seems they are called the "Tri Laminate" tweeter. Is there a model # that goes with that? Is there different models of that named tweeter. Does Polk sell a replacement? or upgrade? and last, any recommendations on caps for replacement in the XO?.
Geesh! is that enough Q's for one post?
G
G
Post edited by gcstokes1 on
HI, From what I've read they don't make the trilaminate tweeter anymore. I think the replacement is a silk dome tweeter. Unless you can find some used you might have to replace both of them so they will sound the same. Give polk a call and I'm sure they will steer you in the right direction.
the replacement for the RT55's is the SL6506's (silk dome). They run $70 each, Polk member $$, from Polk CS.
As far as caps, Sonicap's Gen 1 are really good for the tweeter circuit, Dalton or Solen for the MW circuit, unless youo want to get into some more serious $$. -
Thanks to both for your response and input.
To have to replace both tweeters would be an overkill investment in these speakers. Purchase price plus $140-150 for tweeters is more than I want to spend. I will search for a trilaminate used, then it might be equitable. any thoughts on the RT55 itself?
G -
Curious as to what the original tweeter part # was? I found some SL6001 in the net, $40 pair NOS? Is this the tweeter, or will it work?
http://www.mavin.com/index.php/products/polk-audio-sl6001-trilaminate-dome-tweeter--pair--new
G -
G
I'd call Polk and ask what the original was. Off the top of my head, I don't think that is the correct one for you. It should physically look the same as what you are replacing. The RT55 doesn't have the large round mount like that, its a smaller diameter and I think it clips in from behind the plastic baffle.
