onkyo txsv-727 receiver FS
faster100
faster100 Posts: 6,124
edited May 2003 in Flea Market
Ok here it is, the one i talked about that i gave to my brother in-law, he received it working perfectly, let it sit for a year while he had a room mate, fired it up and some channels are not working.. everything works, the amps are not fried i assure you.. This is what happened, Only the front mains would work but if you moved the binding post they would cut out and get scratchy, I figured cold solder joint?? I removed the back panel reheated all the binding post safely and gently and now the center works and the right channel but no left side and no surrounds... So it needs soldered by a pro, 1 and 2 the amps are not burned up!!
This is Dolby pro-logic only, no optical or coax, has a bunch of dsp's and onscreen display, selective tone and separarete bass and treble controls.. the remote is nice and glows in the dark, has 100 watts for the mains and i think 55 for the surrounds, nice tuner.. and a bunch of inputs and front panel inputs..
Thing is, this has pre-amp outs for all the channels so you can use it as a pre- or get the internal amps working.. your call, I gave my brother-inlaw back his 100 bucks even though it worked when it left..
So give me $50.00 + shipping and its yours, I have the learning remote with it, he has the manual if he didn't lose it, so don't bank on it, I bought this new from circuit city for $700.00
the receiver is for sale here only, the dvd is on another post for sale, 100.00 for both + shipping, or 50 each$$$$
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • faster100
    edited May 2003
    come on, $50 clams
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Airplay355
    Airplay355 Posts: 4,298
    edited May 2003
    maybe if it had optical
  • faster100
    edited May 2003
    well it don't, sorry..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited May 2003
    sold, this case is closed!!!
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
