SuperAntispyware Portable...
Systems
Systems Posts: 14,873
edited March 2010 in The Clubhouse
Hello
I came across this while surfing around the Malwarebytes Antimalware forums this evening....The file name is random so malware can't block it from running...
http://www.superantispyware.com/portablescanner.html
I would like to add that this is not meant to be spam, am not affiliated with these guys in anyway, its only an informative post to anybody thats into removing malware from your own system or anybody elses....
Thank you for your time:)
Testing
Testing
Testing
  • wz2p7j
    wz2p7j Posts: 840
    edited March 2010
    I've used "superantispyware" for years and it works well and doesn't seem to be a bunch of spyware and such.
    Chris
  • seeclear
    seeclear Posts: 1,244
    edited March 2010
    Thanks, picked up 25 adwares on my computer and 33 on my daughter's. Still got to do the wife's.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • Systems
    edited March 2010
    I guess I should add, the only reason I'm really posting about it is because it's made to run from a flash drive....
    Testing
    Testing
    Testing
  • dekuda
    dekuda Posts: 756
    edited March 2010
    Lorthos wrote: »
    Thanks for the posting. I have used this site before and I would recommend it. My boss's computer was real bad and he went to the site and was able to get alot cleaned up. This being downloadable to a usb would be really helpful when you can't get your computer to connect online. By the way, what is up with McCafee? I stopped using them when their protection was not working and their virus scan did not find all of the viruses,spyware and trojans that superantispyware found. Had the latest updates from McCafee. I just stopped using them:(
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
