PSW1000 Dual 10 Sub
Lumpwithgoodear
Lumpwithgoodear Posts: 35
edited March 2010 in Speakers
;)Okay all you Polk nuts I got a question!!! I just purchased a PSW1000 Dual 10 sub cabinet with speakers and bias wired in it! I just purchased a LT500 Elmental Designs plate amp and was wondering how the best to wire it! Should I unwire the bias from the Polk for the LT500 to be wired or won't it hurt to hookup as it! I should know this but............... DUH I feel a little stupied at moment! :rolleyes:lmao! ANY help from you is appreciated!:D
Post edited by Lumpwithgoodear on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2010
    Bias wired?
    I have a PSW1000 also, had a custom steel plate made for the rear, converted it to a 'passive' subwoofer. Haven't decided what to power it with yet.
    What exactly are you asking? How to wire your amp to the speakers?
    Cheers,
    Russ
  • Lumpwithgoodear
    edited March 2010
    Russ yes speakers to amp but my cabinet has the speakers wired to bia control on front and was wondering if leaving it hookup to speakers and installing the LT500 plate amp if it would hurt the amp with the bias it has! OH! Elemental Designs Audio has a separate external amp setup for sale! Check it out!
  • RuSsMaN
    edited March 2010
    I gotcha now, disconnect the front controls alltogether, unless you plan on using the correct replacement amp from Polk. I disconnected them, and plan to use the Polk SWA500 when fundage allows.
    Also, not sure if your PSW1000 came with any polyfill inside, but it will benefit greatly from about a half-pound of 'fill' inside, between the woofers, just don't block the port.
    Cheers,
    Russ
  • Lumpwithgoodear
    edited March 2010
    Russ they did come with polyfill and thanks for the info! I thought maybe I'd be better to disconnect the bias and let the LT500's bias take over! Dang thing came in such a big box that just got it thro the door! lmao! I hope this helps rattle my chest so I don't need a pacemaker! lmfao!
  • RuSsMaN
    edited March 2010
    You HAVE to stop saying 'bias' before I put a flare gun in my mouth.
