Meter lamp replacement on Onkyo m-504 help?
Dabutcher
I just purchased an Onkyo Amp with twin large power meters. No illumination for meters. So I took it apart and cannot find any lamps to replace. So I am guessing at location of lamps.There are two long small boads above meters and there are three spots on each with solder that could of held lamps? My two questions are these. Does it make sense that the light would shine down from above and what lamp number do I order and from where? thanks,Darryl
Post edited by Dabutcher on
Darryl,
Yes, there are bulbs right above the meters.
Looks like two per meter, because one is out on my m506.
I'll be taking it apart soon to try to get a number from the bulb, so I'll try to get a picture (and a part number) for you
KevinRega Planar 2 with Denon DL-110
Onkyo Integra M-506RS dual mono amp / P-306 pre
Onkyo Integra DX-7500 CDP
Polk Monitor 5A, PSB 400, Ascend Acoustics CBM-170
PSB Subsonic II -
that would be so nice of you. Do you have any idea where to purchase replacements? Thanks,DarrylMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Did you guys happen to have the part number for the Onkyo M-504 meter lamps?
