RTI4 vs. FXi3
Hello,
I am still working on completing my home theater system. I have an opportunity o get FXi3's at roughly the same price as RTi4's. Im new to the whole dipole/bipole thing. Which speakers would be the better speakers to get? I only have the capability to use bipole at the moment as the speakers will need to be mounted in the back of the room as there is not enough room on the sides. Which ones would be best in this situation?
_________________________________
Onkyo TX-SR805
RTi8 | CSi5 | F/XiA6
Post edited by JZsFinest on
If they are mounted on the wall the rita4's will stick out quite a bit. They are more deep than wide. May look a little goofy. The FXi's are flatter and wider and will probably look better on the wall. Guess it just depends on the look you want because they will both sound very good as surrounds.Samsung LN52A650 : PS3 : RTi A7s : CSi5 : SVS PC12-NSD : Pioneer VSX-9040THX : Emotiva XPA-3 =
FXI3's will wipe the floor with them 4's for HT . But the rti4 will be superior for multichannel stereo listening .The fxi will work way better in smaller rooms and have a huge sweet spot
