Polk Audio Subs PSW650 Vs PSW505
I have a set up of RT800I Front Speakers & a CS400I Center Channel Speaker & the Rears speakers are the RT600I.Im close to buying either one of these Subs either the PSW650 or The PSW505 both are rated basically the same that i saw which do you think would be the best option or can i not lose either way i decide?I will be using the set up for Home Theather & Music Both.I appreciate any opinions.Thanks Im also using a Sony STR-DE985 Receiver if that helps too.Take care
Post edited by Larryjepson on
  • polkie4life
    polkie4life Posts: 231
    edited March 2010
    I once demoed the psw505 at home and found i couldn't get the sound i was after. I ended up returning it to the store. I settled on the psw650, 2nd hand from a friend.
    The differences to me were not subtle at all. The 650 i found much easier to integrate, for both music and HT. It (imo) dug a lot deeper and had so much more impact and speed than the 505. The tightness and speed were a real plus for music.
    Any chance of demoing them both in home? Everybodies tastes are different?
    In terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
    http://www.polkaudio.com/forums/showcase/view.php?userid=86838
