Reasonably Priced Spade Terminals??
Anyone have any advice on reasonably priced spade terminals? I have Monoprice 12/2 in-wall wire connecting all my speakers with Monster Cable bananas at the receiver end (got a great deal on 6 pairs, otherwise I think they're overpriced at $20 for 2 pair...) and raw at the speaker end binding posts. I'd like to terminate the speaker ends with spades.
I know Monster makes spades and I like the way the monster terminals connect to the wire, but don't feel like spending 5 bucks a piece ($10/pair)... especially since I need 7 pairs and you have to buy in pairs of 2...
Any recommendations? Are these any good:
http://cgi.ebay.com/8-Spade-Plug-Speaker-Cable-Connectors-GLS-AUDIO-P-SR8_W0QQitemZ350135736130QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5185b75742
How about these at $3.50 a pair:
http://www.bluejeanscable.com/store/speaker/index.htm
Post edited by scubalab on
I would avoid cheap brass connectors.
Check these out. http://soniccraft.com/products/connections/spade/vampire.htm"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I am using these, which I think are just re branded Nakamichi spades:
http://cgi.ebay.com/12-Digital-Speaker-Banana-Spade-Plug-Screw-24K-0651954F_W0QQitemZ180472469386QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2a04ff578a
But they are probably the cheap spades Face is referring to. They seem to work fine for me though.
