Polk Surroundbar
Is it possible to wire and use a Polk Surroundbar strictly as a center channel?
Post edited by Dupuis on
You should get acquainted with the below discussion as it covers most aspects of the surrounbars and your question has been discussed a few times.Is it possible to wire and use a Polk Surroundbar strictly as a center channel?
http://www.polkaudio.com/forums/showthread.php?t=35221&highlight=surroundbar
Using the SB as a dedicated center is not impossible but somewhat tricky due to the SDA technology which I believe use some driver's inversion for the rear. You should get acquainted with the below white paper which explains SDA technology.
http://www.polkaudio.com/downloads/whitepapers/SDA_WhitePaper.pdf
As pointed out, this is feasible however willingness from Polk engeneers would be an asset in order to achieve this successfully (if you don't know what you are doing, the sound stage can be worsen ratter than improve)
Good luck!
TKDARE TO SOAR:
