Heartland Interconnect Cables?
outlander
Does anyone have any experience with the sound quality of the Heartland interconnect cables built with Belden 89259 cable and the Eichmann Bullet Plugs? Im curious if this cable would be considered on the warm / smooth side? Id like to find some fairly inexpensive but decent quality interconnects that are not too bright.
Thanks,
O
Thanks,
O
Post edited by outlander on
I bought cables from that seller before.Solid build quality and good customer service.
You could make the same thing yourself and save some cash.
Eichmann bullet plugs are way overpriced.IMO.
Or get some cables from signal cable.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
I know that forum member Gaara was a big fan of the ICs you mentioned. I haven't seen him posting as much lately, but you may want to PM him.2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
