NAD C-375BEE-Integrated-Amplifier with LSI9 ?
Hi,
Going to pick up the LSI9's today. These will be part of my stereo set up used primarily for music. Was thinking of matching these with the NAD C-375BEE-Integrated-Amplifier. Listen mostly to electronic dance music, which tends to be base heavy. Infact this was the reason I went for the LSI9's , where base was concerned it blew away all the other bookshelf's I auditioned .
http://nadelectronics.com/products/hifi-amplifiers/C-375BEE-Integrated-Amplifier
Does anyone have any experience with this amplifier ? think it will a good match for the LSI9's ?
MAC Mini 3.1, OSX 10.6, 2.53 GHZ, Intel Core 2 Duo with SSD & 6 GB Ram, Audio GD NFB-7,2009 Macbook Pro 15" 4 gb ram OS 2.5 Ghz X 10.5.8, Apogee Duet, Signal Cable Silver Resolution Cables & power chords through out the system,Isotek GII Vision, Polk Audio LSI9 speakers (2 pairs, one with Custom external crossover by Sking Ninja), Cayin / Spark AT70 integrated amp, Audio GD Master 1 pre amp, Rotel RB1080 power amp.
Post edited by punit on
That's a great amp and will drive the LSi9's with authority.
The two times I heard the LSi series they where both driven with NAD integrated amps and sounded really nice. -
The Rotel RC-1070 pre amp + RB-1070 power amp combo is available from another retailer at the same price as NAD C-375BEE-Integrated-Amplifier.
http://www.rotel.com/UK/products/ProductDetails.htm?Id=10
http://www.rotel.com/UK/products/ProductDetails.htm?Id=11
any suggestion which will go better with the LSi9's, the NAD or Rotel ?
ThanksMAC Mini 3.1, OSX 10.6, 2.53 GHZ, Intel Core 2 Duo with SSD & 6 GB Ram, Audio GD NFB-7,2009 Macbook Pro 15" 4 gb ram OS 2.5 Ghz X 10.5.8, Apogee Duet, Signal Cable Silver Resolution Cables & power chords through out the system,Isotek GII Vision, Polk Audio LSI9 speakers (2 pairs, one with Custom external crossover by Sking Ninja), Cayin / Spark AT70 integrated amp, Audio GD Master 1 pre amp, Rotel RB1080 power amp. -
Either set up will work well. I would probably go with the Rotel if its the same price. Seperates tend to add some flexibility when upgrading. I also like the Rotel build quality and look better.
Sound wise there about the same. Some might think the NAD is a little warmer than than the Rotel.. -
I currently run my LSI9s with the NAD C355BEE and I think it is a great match. The 355 is the little brother to your amp.Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4
