Help, can't get Netflix to work in Windows 7 64 bit
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,726
edited March 2010 in The Clubhouse
Has anyone with Windows 7 64 bit been able to get Netflix to run? I get very wierd audio issues...
Post edited by AsSiMiLaTeD on
  • AsSiMiLaTeD
    edited March 2010
    Or does anyone know if there's another website that uses Silverlight to stream video so that I can start ruling things out?
  • AsSiMiLaTeD
    edited March 2010
    Nevermind, got it figured out, all's well now.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2010
    So what was the fix? Is Win 64 a problem?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • AsSiMiLaTeD
    edited March 2010
    Not completely, it was a combination of that and the Asus Xonar sound card driver, I had to disable a setting to get it to work.
  • disneyjoe7
    edited March 2010
    Thanks I asked because my wife's laptop is Win 64.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • restanim
    restanim Posts: 227
    edited March 2010
    disneyjoe7 wrote: »
    Win 64? Wouldn't that be like 500 years into the future? :eek:
    polkaudio
    Currently Own:
    RTA-11T Light Oak, Aug/2011 to present
    SDA-CRS+ Aug/2011 to present
    RTA-11T Black, Dec/2013 to present
    Previously Owned:
    SDA-SRS 2.3 May/1990 to June/1991
    SRS 1.2TL June/1991 to May/1995
    SDA-1C Aug/2005 to Dec/2011
    SRS 1.2TL Sept/2009 to Sept/2015
