Peerless Tweeter
drillher
drillher Posts: 18
edited March 2010 in Speakers
Are the newly made replacement tweeter for Peerless 8010665 1" dome as good as the original Peerless?Thanks,
Dave
Post edited by drillher on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2010
    As far as I know...there is no new replacement for the Peerless tweeters.
    There are other tweeters produced by Peerless...but that doesn't mean they're the same tweeter at all.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • drillher
    drillher Posts: 18
    edited March 2010
    There are some offered on ebay from Midwest Speaker Repair said to be made to specs.of Peerless 1" dome.
  • comfortablycurt
    edited March 2010
    Got a link? I highly doubt that they sound the same.
  • drillher
    drillher Posts: 18
    edited March 2010
    Try midwest speaker repair.
  • drillher
    drillher Posts: 18
    edited March 2010
    1" High End Silk Dome Tweeter
    Cast aluminum plate
    8 ohm is a great replacement for Polk Audio, ADS, Peerless and many more.
    4 ohm tweeter is a great replacement for DLK, Domus and more.
    We had these custom made for us designed from the original Peerless 810665 tweeter.
    Very detailed and clear sound. We have been searching for years trying to find a good replacement for the famous Peerless tweeter and now we finally have it.
    Specs:
    1000-20,000 Hz
    50 Watts RMS
    89 dB
    80mm x 115mm (3.15" x 4.53") Flange
    70mm (2.76") cutout
    Add Your Tags:
    Add TagsUse spaces to separate tags. Use single quotes (') for phrases.
    midwestspeakerrepair.com
  • comfortablycurt
    edited March 2010
    These ones?
    http://w.mawebcenters.com/midwestspeaker/ecommerce/home-audio/tweeters/mw-audio-mt-4115-tweeter.html
    I think there are some people on here that I've tried them before...and it was deemed that they didn't sound as good as the original Peerless tweets.
    If you're patient, you could find a pair of original ones for near the same price.
    Might be worth a try though.
    They definitely look very similar...but the domes are slightly different.
  • jimbo1421
    jimbo1421 Posts: 772
    edited March 2010
    madmike tried a pair on a non-Polk speaker. His comment is here:
    http://www.polkaudio.com/forums/showthread.php?p=1136167&highlight=Peerless+Midwest#post1136167
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • drillher
    drillher Posts: 18
    edited March 2010
    Jim,
    Thanks for the link to the review.It sounds like the tweeter may be a good product.
    Dave
  • kcoc321
    kcoc321 Posts: 1,788
    edited March 2010
    I am not sure were the reference to people not liking them is, HOWEVER, Mike's comments are the only ones I can recall, and he liked them ALOT, in fact he said he could not tell the difference:
    madmike wrote: »
    I just got my pair of tweeters today. They look very good, I tried one in my Reynolds Advance A+ speakers today, these speakers have 2 in each, tried the one new one with the old original and I can't tell any difference between the two. I got 2 of them just incase there was going to be any difference between the originals and the new ones,this way I could put one new and one original in each speaker. I will listen to these for some time so this tweeter can have a chance to break-in and I will get back to you guys.
    madmike wrote: »
    Hi guys, between Christmas and New Years I had a chance to really listen to the replacement Tweeter in my Advance Speakers and I was very impressed with the sound. I have about 30 hours on these since refoaming the drivers and the Peerless replacement. IMO there is no difference between this new tweeter and the originals. The amp that I am using is a Carver M-500t and I gave these speakers a really good workout and the tweeter worked flawlessly. I will be upgrading the X-overs in these here in the near future seeing as the speakers are approaching 30 years old so I should probably upgrade them. The tweeters sound the same even by putting my ear to the original and the new one I can't tell the difference between the two. Hope this will help some people on deciding wheather to get these or not. They have two different ones 4 ohm and 8 ohm the ones that I purchased were the 8 ohm which is what were in the speakers originally. The black finish is a little shinier then the originals and the dome material seems a little thinner then the originals. It was great hearing these speakers again for the first time in 16 years.
    I have been considering them, when I go into "upgrade mode"
    Curt, can you link us to the "bad' reviews, that you read?
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited March 2010
    It seems like you are trying to market Peerless tweeter knock offs or whatever instead of helping others or looking for help.
  • drillher
    drillher Posts: 18
    edited March 2010
    Not true,I just wanted to know if they were good vs.the old originals that are sometimes for sale on ebay.
