Replacing single caps with parallel combinations
inspiredsports
inspiredsports Posts: 5,502
edited March 2010 in Vintage Speakers
It seems new capacitors are physically much larger in size than their older counterparts, and also that large value caps are relatively expensive. Because of this, most of us typically "piggyback" (install in parallel) 2 lower value caps to get the higher value.
For example, two 20uf's are used to replace one 40uf.
I've been told that using equal value caps to get to your target is best (20 + 20 as in my example above), but that 10 + 30 is also fine.
I've then heard however, that 5 + 35 is not a good idea because the low value cap becomes the "path of least resistance" and begins to act as a bypass cap.
Beyond the theoretical ratios of what should be used, does anyone have any practical knowledge about what combinations might actually sound better?
Asking another way, using same brand caps, does a single 40 sound the same as 10 + 30?
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
Post edited by inspiredsports on
  • Deadof_knight
    Deadof_knight Posts: 980
    edited March 2010
    if your gonna use use two in parallel then they need to be equal amounts to work correctly.
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • ben62670
    ben62670 Posts: 15,969
    edited March 2010
    Try to stick with caps nearest to the same values to makeup the total.
    Ben
  • inspiredsports
    edited March 2010
    Am I imagining it or were there a few additional responses here earlier in the day?
    NAD SS rigs w/mods
    GIK panels
  • Face
    Face Posts: 14,340
    edited March 2010
  • strider
    strider Posts: 2,568
    edited March 2010
    Face wrote: »
    That's odd. Forum software glitch?
    Wristwatch--->Crisco
    heiney9 Posts: 25,409
    edited March 2010
    So have you found (2) 20uF to be a whole lot less expensive than (1) 40uF cap? I could see where there might be a huge cost difference or a real estate issue otherwise why not just the single correct value...........that will work best in most cases.
  • xukaxuka3
    xukaxuka3 Posts: 1
    edited March 2010
    I accept with information: It seems new capacitors are physically much larger in size than their older counterparts, and also that large value caps are relatively expensive. Because of this, most of us typically "piggyback" 2 lower value caps to get the higher value.
  • inspiredsports
    edited March 2010
    edited
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited March 2010
    strider wrote: »
    I must have had an edit copy of my original post open and posted it twice as the link Face provided in post #5 above leads to my original post.
    NAD SS rigs w/mods
    GIK panels
