RTi6 overpower for surrounds?
As you all might have read, I recently purchased RTi8's and CSi5 for my new front speakers. I was wondering if you guys thought that RTi6's would be overpowering for use as surrounds or rears? Would RTi4's be more appropriate? Would the newer RTi A series be a step up?
_________________________________
Onkyo TX-SR805
RTi8 | CSi5 | F/XiA6
Post edited by JZsFinest on
They would not be overkill. I would use the 6's.Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
i dont think the 6's would be overpowering. i have the A5's and the A3's as rears. These are basically the same as you rspeakers and are only the newer model. i think it sounds great. At first I was worried about the size. The A3's are pretty big for surrounds. I got some speaker stands and they worked our great.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
I used to run some RTi8's and a CSi5, with RTi6 surrounds. I never once felt that they were overkill.
I never had the 4's for comparison...but I didn't really need to.;)
As far as the RTiA series being a step up? Yes, and no. They sound better...but very incrementally so. The RTi6's have about 95% of the performance of the A3's.
If you're looking for a step up from the RTi series...moving to the RTiA series won't really give you much of an improvement IMO.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
See my sig line. The Rti6s are great as surrounds but you could save some coin and use the RTi4s in the rear. If you are running 7.1 then consider the 4s in the rear and as mentioned FXi3/5s as your side surrounds.Shoot the jumper.....................BALLIN.............!!!!!
The rti6's work just fine for the rears. I have been using mine for over a year and am very pleased."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic
