1812 Overture!!
stevew14
stevew14 Posts: 130
edited May 2003 in Music & Movies
I just listened to the Cincinatti Symphony Orchestra performance of the 1812 Overture included on the Telarc disk "The Best Of Tchaikovsky" again. A while back I added a second amp into my mix. Now using two Carver TFM 35x. One for each rti150. Vertical bi-amping using one channel for the three 3-6.5", and the other for the mid driver and tweeter. Source is Toshiba dvd9200, analog out through some recently added Kimber Heros to Parasound PLD 1100 pre. Speaker cables are vintage Kimber 4PR runs.
The cannons toward the end of the piece simply blew me away! They were impressive before, but now unreal!! The meters on the amps were peaking at around sixty watts during the "blasts". I tell you what, sixty watts sure does make some sound.
Ultra quick, extremely punchy and clean as a whistle! Not sure if the Heros changed things, but the difference between then and now was enough to inspire this rant. The extra amp definately opens things up. I noticed that right off.
Anyway, for those of you that appreciate classical music, I highly recommend you check ou this disk if you don't already have it. The number on it is Telarc CD-80539. Definately worthy of anyones collection. I know others have mentioned it here before, but it's been awhile and I felt the urge for a reminder.
Enjoy, I think I need some more!
Later, SW
Post edited by stevew14 on
  • TonyPTX
    TonyPTX Posts: 545
    edited May 2003
    I'll second this. The 1812 is a nice piece of classical work that WILL put your bass sub-system to the test.....FIRE AT WILL :D
    Damn....8 lines...I've gotta put my sig on a diet now....
  • Soccerplyr
    Soccerplyr Posts: 160
    edited May 2003
    Didn't know this one existed! My day would play the 1812 early in the morning when i was growing-up so I've always had an affinity for it. Heading to tower tonight to pick it up. Thanks
    Jeff
    Pioneer Elite VSX-21TXH
    Monolith 7x200 Amplifier
    Harmony Hub
    Sony VLP-HW40ES
    Visualapex 106" Electric Screen
    Oppo BDP-103
    Music Hall MMF 2.1
    Polk LSiM 705
    Polk LSiM704c
    Polk LSiM702F/X
    SVS PB-2000
  • Tour2ma
    Tour2ma Posts: 10,177
    edited May 2003
    WARNING... Digital Cannons...
    More later,
    Tour...
    Vox Copuli
  • TonyPTX
    TonyPTX Posts: 545
    edited May 2003
    Are they really a digital sound effect? It would make me upset if they were....
  • pensacola
    pensacola Posts: 269
    edited May 2003
    Digitally recorded.
    "Digital cannons" was Telarc's way of saying "caution" when they
    came out with their digitally recorded "1812" in 1979--before CD's.
    I have the record, and you can see where the cannon shots
    are on it as the grooves are about 1/8" apart--allowing for
    the huge lateral shifts necessary for the sudden "whacks".
    That, and the fact that it contains information in the 8-16 Hz range
    means turn it down--at least for the first playing.
    Give War A Chance
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited May 2003
    Originally posted by pensacola That, and the fact that it contains information in the 8-16 Hz range
    You haven't heard/felt these cannon blasts unless your sub can play down to at least 15 Hz. Talk about room decay - holy momma! These cannons hit you hard in the chest, and then the subsonic percussion blast just waffles through the room. Amazing stuff.
    Great post! What a classic movement.
    Doc
    SVS
  • STUFFMD
    STUFFMD Posts: 381
    edited May 2003
    Hey Pensacola I've got the Telarc vinyl as well...most turntables/cartridges had a hard time tracking that gap.....very cool to watch..album/vinyl looks like a stock market graph. I have never heard more bass on a recording personally.
    Stuff
    Your system is only as good as your weakest component...!
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Center: Cs400i /Biwired
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    Vision RCA 36" Premiere Series
    Bang & Olfsen RX Turntable
    Psw 350 Front/Psw 202 rear
    Kimber Cable 4TC Mains HF
    Monster Originals/Center
    Kimber Interconnects
    Monster XP Everywhere else
    PS2/Gamecube
