hk avr225
edited May 2003 in Electronics
Anyone have the harman kardon avr225. I bought it six months ago to replace a sony 1075es. I'm having trouble with the center channel seeming to be loud enough. I use a spl meter to calibrate the system. I dug the sony out this weekend and hooked it back up because there is definately a difference. I don't know if I should send the unit in for service or just try and get rid of it. Any suggestions? By the way the center channel is a csi400
Post edited by rhulett on
    edited May 2003
    I'm not sure if you're aware of this, but you can change the volume of each channel independently. So try turning your Center channel up. I actually do have the 225, and I like it, I've found it to be a strong reciever. So if it's very weak, there's probably something wrong.
    edited May 2003
    I should add, you can access that channel adjustment through the On Screen Display, and there's actually a button on the remote labeled OSD that will get you there.
Welcome!
Welcome!
