Speaker purchase
I currently have two Polk RTI A7. I'm looking at switching to the Polk LSI 9S. Using them 50/50, two channel music and HT. Any recommendations from anyone that has had both. Any feedback on spending this kind of money to get the better speaker would be appreciated.
Post edited by rmoody on
I have heard both the RTi A7's and the LSi's at a local shop, the LSi's are by far the best home theater speakers I have ever been able to listen to. Too expensive for me though. Would you selling your RTi A7s?
What would you be powering it with? Keep in mind that the LSi's pretty much require an amp capable of driving a 4ohm load.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
^^^^^^^^^^Good Point^^^^^^^^^^^
The RTiA's are relatively easy to drive. Don't expect a significant upgrade in sound unless you give the LSi's the kind of power they need."Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
no i would not be selling the rtia7s iam still with in my 30 days
i wll be powering them with a h/k 3600
Not sufficient to power the LSi's IMO. Those LSi9 dip down below 3 ohms at certain points. That AVR will run extremely hot and you will not get that much out of them at that rated power.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
+1 on this...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
