Fx 1000
These speaker will be going on my back wall I was wondering how far apart these should be mounted. I read that they should be approx. 2-3 feet above the listner. Do they mean to the bottom of the speaker or to the tweeter? The back wall is 17ft.,open on one side.
Thanks,
Rob Stern
Thanks,
Rob Stern
mains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
Post edited by RSTERN on
Rstern,
Take a look at this thread, it might help.
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=9756
I can tell you that if you mount the speakers so that the tweeters are 2-3' above ear level they'll probably get knocked off the wall or cause some severe Dain Bramage! Better measure from the bottom!
