PA1200.1 amp
![Amit1591](https://w9.vanillicon.com/90562d038eec523fe70ae47cbb09e499_100.png)
Amit1591
Hey this is kind of a dumb question but i just cant figure it out. I just bought a Polk Audio PA1200.1 amp and I want to remove the end caps because they are in the way when wiring and trying to mount the amp. Are the end caps on the amp removable and if they are how do your remove them. Thanks.
Post edited by Amit1591 on
They are.
U gatta take off the cover first (4 screws/holes u see on top)
Then there's a few screws to separate endcaps from the cover itself.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
