PS3 only player
wayneniamat
wayneniamat Posts: 6
edited March 2010 in Music & Movies
I'm guessing I'm not alone, unexpectedly rediscovering 2-channel music while building a multi-channel home theater on a shoe-string budget.
I'm using a 40gb SONY PS3 which does NOT play SACD as my player and I'm stuck with that for now.
I've taken to converting flac files to .wav for playback from the ps3.
Is there anyone else in this stage of evolution? I'm consumed with finding the highest fidelity 2ch and multi-ch content that I can play on my 40gb ps3.
What's out there?
Post edited by wayneniamat on
  • nguyendot
    nguyendot Posts: 3,594
    edited March 2010
    I'm using my laptop with flac right now in my rig. Sounds great.
    Main Surround -
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited March 2010
    Using my laptop with music ripped in apple lossless going threw a usb dac sounds great as well.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • nguyendot
    edited March 2010
    Yeah I need to find a new USB dac, using a creative MP3+ right now.
    It's useful though, I take it outside and attach it to my "ghetto blaster" and it works well.
    Main Surround -
  • concealer404
    concealer404 Posts: 7,440
    edited March 2010
    Have you tried just putting CDs in your PS3 and playing music like that? :p
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2010
    LOL, you are living in the stone age. That's the way I do it for now, but my 80GB does SACD, so I am getting ready to dabble in that soon.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • cheddar
    cheddar Posts: 2,390
    edited March 2010
    There are also some blu-ray concert and the rare blu-ray music only disk. Look for 24bit/96khz and 24bit/192khz blu-rays for the high quality stuff. The latter tends to be only classical and the like from companies like 2L.
    edited March 2010
    cheddar wrote: »
    Good point....that might be your 'best' sounding music....it might also help to put some better DACs between your PS3 and your AVR or whatever power source you're using......
    I also use my laptop, google's PS3 media server and a higher end Onkyo AVR in the mix. But that's more for 'casual listening'....Of couse I record everything as a wav lossless file--and stream it to the PS3..
    cnh
  • wayneniamat
    edited March 2010
    THANKS for the suggestions all. 'google ps3 media server'? So everyone's streaming. Hmmm.
  • cheddar
    edited March 2010
    You can also store files locally if you want. For 50 bucks or so you can change the internal hard drive out for a 320GB or larger one. Really depends on where you find most convenient for all your files. It can also access external drives via the usb ports. Just have to make sure the external drive is formatted fat32.
    The ps3 internally uses generic SATA laptop size hard drives. There are plenty of 'how to' videos of how easy it is to change one on youtube. Basically pop the little plastic door off, unscrew one screw, slide the old one out, transfer the cage to the new one, reverse. Then the ps3 prompts you to format the new drive on boot up. A few extra steps are necessary if you want to save data from the old drive.
  • wayneniamat
    edited March 2010
    I downloaded a file from NL2 that is 96khz and 24 bit but it isn't playing on my ps3. I tried toying with the MUSIC and SOUND settings but nothing doing. Any advice?
  • The 7th Taylor
    The 7th Taylor Posts: 8
    edited March 2010
    Even if your PS3 doesn't play SACD (and I know the 40GB one doesn't) it still plays DSD Disc format. See http://www.ps3sacd.com/dsddiscguide.html
    This may be the highest fidelity 2-channel media you can find. The only issue is that unless you record some yourself you will not have much content (yet).
