L, C & R outputs on Receiver question
jemrey81
Hey guys, bear with me on this one
My receiver (as all do) has the output levels for all of the channels, I am wondering what do you recommend setting them to.... or is it a "whatever sounds good to you" thing? I am only running the front 3, and a sub. Currently my L&R channels are at +2.5 and the center is +3.5 out of 10 (IIRC). Should they all be that same? Should they be set higher? Do I need to give out componant info?
Post edited by jemrey81 on
Using a sound meter works best.Michael
NORTH of 60° -
+1, or if your AVR has a auto calibration program, run that and it will take care of it for you.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Whatever is the lowest sounding channel/s you want set to 0 gain and then pot up whatever channel is behind. For example the Left and Right would be at 0 and then +1 on the Center channel.// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
// Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
// Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
Photo Gallery
Movie and Game Collection
