Hafler amps
gdphoto
gdphoto Posts: 182
edited March 2010 in 2 Channel Audio
Hi, I use a Hafler DH110 preamp and a Hafler DH220 power amp. I'd like to know where everyone would put these in the pecking order of good audio equipment?
Hafler DH220 Power amp Recapped
Hafler DH110 Preamp Recapped
Hafler Digital FM Tuner
Virtue Audio M1 Piano CD Player
Technics SL-1210-MK5 with an Ortofon Black LVB250 Cartridge
Polk SDA1c's(Rebuilt XO's by Ben) RDO194 Tweeters
Post edited by gdphoto on
  • dougy
    dougy Posts: 182
    edited March 2010
    Sound quality-wise, I'd put them way up near the top. (I really like mos-fet amps.) In terms of build quality, maybe down a few notches from the better affordable gear.
    BTW, I owned the 110 pre, the tuner and the 500 amp back in the early 80's. The amp was a beast, but I had issues with the power switch.
    Looks like a really good system!
    THE MAN-CAVE 5.1 CHANNEL A/V RIG
    Sony KDS-60A3000
    a/d/s/ HT-400LCR (3)
    a/d/s/ HT-300 (2)
    Velodyne DLS-4000R (2)
    Pioneer Elite VSX-55TXi
    Pioneer Elite DV-47Ai
    Sony BDP-S300
    Sony SLV-779HF
    DirecTV HD sat. receiver
    MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
    Adcom GFA-5500
    Bose 901 Series VI
    NAD C-165BEE
    Slim Devices Squeezebox Classic
    TEAC CD-RW890
    Technics SL-BD20D w/ Audio-Technica P34
    Akai HX-A3X
  • gdphoto
    gdphoto Posts: 182
    edited March 2010
    I had to replace the 220's power switch too. Any thoughts on replacing the caps, and or the modification I've been hearing about.
  • dougy
    dougy Posts: 182
    edited March 2010
    If they're original, they're probably due. But as for what to replace them with, I really wouldn't have a clue what would be the best. Is there anybody out there specializing in Hafler mods and/or maintenence? As many Hafler amps are being used, I'm sure there's got to be.
    Sony KDS-60A3000
    a/d/s/ HT-300 (2)
    Sony BDP-S300
    Sony SLV-779HF
    Adcom GFA-5500
    Bose 901 Series VI
    NAD C-165BEE
    TEAC CD-RW890
    Akai HX-A3X
  • lhester
    lhester Posts: 12
    edited March 2010
    gd,
    I have two DH-200s running subs. They are pushing 30 years. I had to have the bias circuit repaired on one. I bought PS caps off e-bay for $50 a set. They are 18,000pf each instead of 10,000. I can't remember his ID, but just do a 'hafler' search and they should show up.
    I have the complete IRIS system-Pre, CD Player, Tuner. 20 years with no problems. LH
    edited March 2010
    I don't know where I'd put them and have never owned them...but had friends who did. Those were very warm sweet sounding pieces....I would buy them 'used' even today in an eyeblink!
    cnh
  • gdphoto
    gdphoto Posts: 182
    Just an update, I replaced all of the caps awhile ago and it sounds great! Even replaced all of the caps in the 110 pre amp.
