Suggestions? Am I going Wrong Anywhere?
PolkNewb
PolkNewb Posts: 45
edited March 2010 in Speakers
Am currently putting together a system and want to know what you all think. It is for a decent sized 20 x 20 living area.
Polk TSi 500 floorstanding speakers
Polk TSi 100 bookshelf speakers
Polk CS 10 Center Channel
Polk PSW 110 10" powered sub-woofer
Yamaha RX-465 Receiver
Monster XP speaker wire
Any input welcome and appreciated
Jeff
Post edited by PolkNewb on
  • Rodeo0530
    Rodeo0530 Posts: 797
    edited March 2010
    I have a Monitor based setup, but I would go for the CS20 center because you will ultimately be happier with it probably. The center puts out a lot of sound for your HT. I would look at monoprice.com for speaker wire. It's cheaper and it's plenty good enough to get you started. That's all I can really contribute to ya, other than welcome to CP!
    Front - Polk Audio Monitor 70
    Center - Polk Audio CS2
    Rear - Polk Audio TSi 100
    Sub - Klipsch rw-10d
    AVR - Onkyo ht-rc180
    Main Amp- Parasound HCA-2003
    Surround Amp- Sonance Sonamp 260
    Tuner- Parasound tdq-1600
    Turntable- Pro-ject Debut III USB w/upgraded platter
    IPod dock - Pure i20
    TV - Panasonic Viera tc-p46g10
    Sony Playstation 3(250GB)
    Nintendo Wii
    Power Conditioner- Panamax 5100
    Not in use-
    Polk Audio Monitor 60
    Polk Audio PSW10
    Parasound p/sp-1000
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    Awesome thanks alot
  • lmacmil
    lmacmil Posts: 122
    edited March 2010
    PolkNewb wrote: »
    Jeff
    Speakers are fine. Save your money on the Monster wire and just get the appropriate gage wire from Monoprice. Get the PSW505 sub from Newegg for the same price as the PSW 110.
    Get a Yamaha RX-V765 for about $70 more than the 465 at Newegg on sale. It's been $400 three of the last four weekends. Check first thing Sat and Sun or put a price alert at $400 to get an email when it goes on sale.
  • Huck344
    Huck344 Posts: 453
    edited March 2010
    +1 on the monoprice speaker wire. If you can, upgrade your AVR. Then again, with the savings on the speaker wire, it might be a wash. No CDP/DVD/BDP?
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    Sorry it will coupled with a PS3
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2010
    I'd recommend moving up to the CS20 center channel. The 500's are some big speakers, and the CS10 would have trouble keeping up with them. The 20 would be a much better choice IMO.
    You've obviously got to work within your budget, but I'd recommend looking into a bigger sub as well. As I said before, the 500's are some big speakers. A smaller sub will have some trouble keeping up.
    Also, pass on the Monster wire. You can get something every bit as nice for much less money from either monoprice or Signal Cable.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • McLoki
    McLoki Posts: 5,231
    edited March 2010
    I would say more like:
    similar quality at a much cheaper price from MonoPrice or
    similar price but much better quality from Signal Cable.
    Either way, I would put both as a better choice.
    Michael
  • Slinger182
    Slinger182 Posts: 512
    edited March 2010
    +1 on the CS20 it was my first speaker when I started building my system.
    Also if you haven't already gotten that AVR I would consider getting a different one that has pre-outs my only regret in building my current/1st system is that I don't have pre-outs...
    Panny 55-st30 plasma
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk TSi500s Vr3 Fortress modded
    polk CS20 center channel Vr3 Castle modded
    polk Owm 3 surrounds
    polk PSW505
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    Slinger182 wrote: »
    Does the Yamaha 465 not have pre outs? I thought it did and I thought it was a pretty awesome receiver?
    On the issue of the CS20 would the TSi 400's work better with the CS10 and PSW110?
  • Slinger182
    edited March 2010
    No it doesn't have pre outs. Only for the surround backs and the subwoofer. I checked out that receivers specs and it seems to me to be a very good beginner receiver. I've never heard it but it does decode the latest HD codecs. You only need pre outs if you plan to upgrade to an external amp down the road. The TSi line of speakers are pretty easy to drive so that receiver can definitely get the job done.
    Will the CS20 not fit into your entertainment center or budget?
    I'm sure others will chime in. I'm pretty much still a newb as well. My best advice is to stick around and try to learn as much as possible before you buy. There is a ton on info and experience from all of the other users to learn from.
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk PSW505
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2010
    The 465 does not have pre outs for adding an external amp, for $300 or so dollars I would say it is towards the bottom of the food chain in Yammy's lineup and they tend to not have the features the "better" models do. It does do the new HD codecs and has 4 HDMI in, but other than that, it is a pretty basic AVR. I am with the other posters on getting the CS20 instead of the CS10, those 500's are pretty big speakers (I was surprised how big when I got mine) and the CS10 will have a hard time keeping up with them, even if you boost it. Something like 50-75% of all audio is played by your center, esp. dialogue and you don't want to skimp on it. I usually recommend the biggest/badest center you can afford/fit in the space allowed. Even if you went with the 400's I would still recommend the CS20 over the CS10. Also, I would recommend you step up to the PSW505, you can get them brand new from Newegg for $250 with free shipping, it's not the best sub in the world, but for the price it is hard to beat. Good luck.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    Thanks for all of the input, I think I will hold out for the CS20 and the PSW505, for the receiver, I can get the Yamaha for $250 now, for that price range it is hard to beat? Could I get anything markedly better in the under $500 category. As far as pre outs go I am not terribly concerned with adding amps for now, I just want a nice set up that I can be happy with for a few years while I watch TV, game, and watch movies, so this will more than get the job done agreed? Then down the road if I want to step up I can look at updating the receiver? Any other input? Thanks
  • wutadumsn23
    edited March 2010
    Sounds like a good plan, just don't say we didn't warn you when you want an amp in a few months, lol. Stay away from this forum if you don't want the upgrade bug to bite, lol. I think you will be happy with the CS20/505, just keep in mind that the CS20 is a beast, and can be hard to fit in most racks/entertainment centers. That 465 will be more than enough to satisfy your needs for now, and like you said you can always upgrade later. In the $500 category you will be hard pressed to find anything that has pre outs, but you can sometimes get lucky in the used market. There is a reconditioned Onkyo TX-SR606 on Accessories4less.com for $300, which is a good price for that AVR. It has gotten some very good press, and has just as much, if not more in the way of options as the 465. Comfortablycurt has one, and besides the lack of pre outs, he has been very happy with it. Just an idea.
    -Jeff
    http://www.accessories4less.com/index.php?page=item&id=ONKTXSR606 link for 606
    HT Rig
    Blu-Ray- 80 GB PS3
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    -Jeff
    Very good, thanks man!
    Jeff
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    One last question, are the TSi 100's enough for my bookshelfs? I know that you ideally like to hear most of your sound up front and use the bookshelf speakers as support, for the money the 200's seemed like a bit of overkill for what I want
  • wutadumsn23
    edited March 2010
    I had the Monitor 40's as my surrounds, until I recently got a pair of TSi 500's that I am planning on building a 2 ch. system with. In the meantime I hooked them up as surrounds, so as you can see there is no such thing as overkill for your surrounds, lol. In all seriousness though, the 200's will work fine as surrounds as would the TSi 100's, basically it is up to you. Both are solid options. The Monitor 40's are very similar to the TSi 200's and I was very happy with their performance as surrounds.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • hagmanm2
    hagmanm2 Posts: 205
    edited March 2010
    I figured I'd throw my ¢02.0 in since my setup is so similar to what you're looking at. I briefly had the CS10, TSI200s, and PSW111 before selling it all to contribute to my current rig (though there was an overlap time where I had TONs of speakers! :p).
    That being said, I agree with what everyone is telling you. With the right receiver, the 500s grab a lot of base, and easily overpowered the psw111. I know the 111 is smaller than the 110, but I still suspect that it won't do as good a job filling in the lows as the 505.
    The CS20 will definitely match up with the 500s much better than the 10. As everyone said, it was just too small: it was easily noticeable even for my unseasoned ears.
    As far as receivers go, I went from an Onkyo sr504 to sr606 to Denon 3805. The Denon was a monster improvement! It has pre-outs, a phono input (big plus for me), and runs 120WPC. The 500s sounded... cleaner and fuller (not sure how else to describe it), especially as the dBs went up. Hands down a better receiver than the 606 IMHO.
    However, it doesn't have HDMI. That being said, I don't see why you couldn't just pass the HDMI to the TV and run the sound through the AVR? What's the downside of that? I'm sure other people know. For me, whenever I upgrade to Hi Def, I'll be happy hooking up my system that way... unless this forum learns me otherwise ;)
    the 3805s are selling around 350 on ebay. Not a bad deal methinks.
    Good luck hooking it up. And I definitely wouldn't step down to the 400s. TSI500s FTW! :D
    Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
    Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited March 2010
    The 465 does not have pre outs for adding an external amp, for $300 or so dollars I would say it is towards the bottom of the food chain in Yammy's lineup and they tend to not have the features the "better" models do. It does do the new HD codecs and has 4 HDMI in, but other than that, it is a pretty basic AVR. <snip>
    -Jeff
    Definitely go above the 465 level. I have the 663 (Yamaha increments their model years by last digit) and their current version of the same I got is the 665. This unit has all of the features you want for expansion, options, better decoding, etc for more of a serious starter system that has long term possibilities.
    When buying, I was prepared to go one level higher in the Yamaha HT series, but the price increase for what you got (value) did not gel.
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    So it definitely looks like the only thing to re-evaluate is my choice in AVR. I do want to stay around $500 or under for now which is why I was questioning the ability to find something markedly better than the 465 in that ballpark that was new. Just a personal preference but I don't usually buy re-conditioned or used...not that I am too uppity too, just had a couple of really bad experiences with it that turned me off for good.
    One more question....what do all of you think of service plans? I have my own opinion on them, for my TV's I always have bought them and actually needed them both, as the LCD bulbs burnt out, however, for something like this system by the time you would buy all of the service plans you would end up adding probably over $300-$400 to your total cost, I guess what I am really asking is how good Polk's warranty is that things that the service plan would also cover.
  • kevhed72
    kevhed72 Posts: 5,129
    edited March 2010
    I would skip the service plans and put that $ into your system, probably into an AVR a step or 2 up the ladder. I also agree with the previous posts...go with the PSW505 and the larger center channel, and replace the Monster wire with something from Monoprice or Blue Jeans. Just my .02.
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    Ok, so I have pretty much decided now to step up to the Yamaha RX665. Has anyone used this receiver? What are your thoughts, any problems? I have a Direct TV HD DVR box, does anyone know who makes that box? Has anyone had any problems with compatiblity with this box?
  • kevhed72
    edited March 2010
    You should be able to hook the HD DVR right to the AVR via a single HDMI cable. Save yourself alot of $ and just get your HDMI cables from Monoprice or Blue Jeans cable.
  • Hillbilly61
    edited March 2010
    PolkNewb wrote: »
    Advice: Shop the Yamaha RX-V 665. You can find it at a price better than you quoted.
    That said, one of the first things I did was hook my RX-V663 unit into a DTV box. There are lots of boxes being used for/by DTV. Anyhow, I do not think you will have any problems interfacing your DTV box into a 665 unit.
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    Im back guys lol, just had a question on the speaker wire, since I rent for now the wire will not be through the wall, any suggestions for keeping it ultra clean i had just planned on running it super tight along the walls and using some tape to keep it in place?
    Also I know earlier I eluded to the fact I was thinking about using the Monster XP wire but everyone here is turning me on to monoprice.com. I know there are tons of concerns with speaker wire and sound quality, so I take it you have all had great luck with the wire that is sold at monoprice? Additionally I should be using 16 gauge wire right?
    Thanks,
    Jeff
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    Are the cable raceways a good way to conceal the wire, or do they sell something similar at a hardware store
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    Additionally what cable would I use from receiver to sub from monoprice?
  • Todd Lee
    Todd Lee Posts: 73
    edited March 2010
    Subwoofer cable.
    http://www.monoprice.com/products/search.asp?keyword=subwoofer+cable&x=0&y=0
    I personally use
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=3976&seq=1&format=2
    As for speaker wire, just find the largest gauge you can fit into your terminals on the speaker and receiver. typically 16 to 12. The smaller number, the thicker the cable.
    Pioneer 1018
    Polk RTIA5's
    CSIA6
    RC80I's
    SVS PB12-nsd
  • Huck344
    Huck344 Posts: 453
    edited March 2010
    PolkNewb wrote: »
    Thanks,
    Jeff
    I have the monoprice 12 gauge speaker wire and like it. I actually had the Monster wire was well. When I moved, I had to buy new wire because of longer runs. I did an A/B comparison with the monoprice wire and really couldn't tell a difference at all.
    If you want it clean, I would definitely use cable raceways. cableorganizer.com has lots of options, but I think they are a bit pricey. Depending on your run length, number of wires, etc, you can probably pick up raceways at Best Buy or Frys.
  • wutadumsn23
    edited March 2010
    hagmanm2 wrote: »
    The only downside of that is if you run it via Digital Coax or Optical (TOSLINK) you won't be able to take advantage of the new HD codecs, since neither one of them will pass the signal, you will get DD. You could always send the audio via 5.1 or 7.1 analog out to your AVR, assuming both of the units you will be using support that connection. Then you will be able to get the HD codecs.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • PolkNewb
    PolkNewb Posts: 45
    edited March 2010
    So what gauge speaker wire should I go with....I have been hearing 16 gauge from alot of people.
