What Amp should i get for 4 MM6501UM Speakers?
rocktheboat
I just bought 4 MM6501UM speakers for my boat, then i realized its really hard to find a marine amplifier that can feed the power these babies need. Ive been told that having an amp with less power than what the speakers need is bad for the speakers and at the moment i haven't found any marine amps able to properly feed the MM6501UM. Anyone know of an amp that can handle 4 of these speakers (125 Watts RMS each).
So its clear it needs to be marine because i navigate on salt water.
