Help needed for my LSi9's
dhart86
dhart86 Posts: 1,594
edited March 2010 in Speakers
Hey guys. I'm a newbie and need some advice on getting the best sound out of my LSI9s, I bought them pre-owned. They are bi-wired to a Rotel rb991amp and rc1070 pre for music. It sounds like the music is coming from inside a box. Somewhat muffled.
Is there a way to make it sound more forward. I am waiting for stands, but temporarily (and shamefully) have them sitting on wooden TV tray stands
However the sound is not up front so to speak!
Is there any help available
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Post edited by dhart86 on
  • maximillian
    maximillian Posts: 2,145
    edited March 2010
    How is your positioning? LSi9's can sometimes be difficult to position correctly. How far apart are they? Are they towed in? How far away are you?
  • dhart86
    edited March 2010
    They're about 11 ft apart, towed in and my listening position is about 13 ft away
    Main Rig:
    Second Rig:
  • Montoya
    Montoya Posts: 506
    edited March 2010
    I had to experiment with position with mine I did a lot of reading and used the rule of thirds in the end. It gave me the best results but it was a good amount of hours before it was perfect.
  • Montoya
    Montoya Posts: 506
    edited March 2010
    How far away from the back wall and side walls? What's the room dimensions?
  • maximillian
    edited March 2010
    Wrong "towed", oops :)
    That's about my setup too, and my room is only medium size. A quick search mentions some people having problems with the tweeter resistor on the crossover board. However, I seriously doubt both of them would blow or come loose, unless the previous owner was very abusive.
    I power mine with a Rotel RB-980BX and it doesn't sound like it's muffled, although the LSi's are generally laid back. At low volumes the soundstage is a little flatter than at higher levels. At medium and higher levels, singers voices are definitely airy and slightly forward. Your gear seems good enough. What type of music have you experimented with?
  • dhart86
    edited March 2010
    My speakers are about 3 ft from back wall and 5ft from side wall in a medium size room.
    Main Rig:
    Second Rig:
  • dhart86
    edited March 2010
    Yeah Max.
    I did me "toed in" Thanks for the feedback. I mostly listen to jazz, rock, R&B. My listening level is usually low to med. Guess I'll have to do some daytime, nobody home listening.
    Thanks again
    Main Rig:
    Second Rig:
  • markmarc
    markmarc Posts: 2,309
    edited March 2010
    Having owned the LSi9's, I'd dump the bi-wiring for starters. Put the jumper bars back in the binding posts, or create some jumpers. Secondly, be patient until the stands arrive, then plan on spending a few days playing with the position. The LSi's are not typical Polk speakers, they have a very different sonic signature.
    Former Staff Member TONEAudio
    2 Ch. System
  • dhart86
    edited March 2010
    Thanks for the advice you guys..I'll put the jumpers back on and straight wire the speakers. I'm glad you gave me some things to try to improve the sound. I was thinking about going another way, speaker-wise. Anonymouse, since you have the same amp, I'm eager to see if I can get the same pleasing results. How difficult is it to mod the speaker crossovers? Thanks for helping me get my head back in the game
    Main Rig:
    Second Rig:
    F1nut Posts: 50,814
    edited March 2010
    11 feet apart is pretty far, try 6 to 8 feet.
  • dhart86
    edited March 2010
    Yeah, I know...but I got two 3ft wide bookshelf towers on either side of a 60 in lcd tv and the speakers are on the outside of each tower. room dynamics kinda dictate speaker placemnt. However, I'll move them in to 6 ft to check sound. Thanks
    Main Rig:
    Second Rig:
  • dhart86
    edited March 2010
    OOOOH SH**T, I can't believe how much difference positioning makes with these speakers. I moved the speakers in to about 7ft apart and toed in to my listening position 10 feet away and boom!! These speakers are sounding like the reviews I've read. Crisp , clear, but a little laid back. Now I can't wait to get my DAC back from Pacific Valve on repair. ( I don't recommend buying anything from them)
    Thanks to all!!
    Main Rig:
    Second Rig:
  • steveinaz
    steveinaz Posts: 19,538
    edited March 2010
    You'd be amazed how much 1" can make a difference with speaker placement.
  • dhart86
    edited March 2010
    yeah Steveinaz, I see! I'm learning a great deal thanks to this forum
    Main Rig:
    Second Rig:
