BDP-05FD firmware disc
cstmar01
cstmar01 Posts: 4,424
edited April 2010 in The Clubhouse
Does anyone have one I could use? Apparently the guy I bought this from lied about upgrading the firmware. Right now they are on version 1.38 and mine still has 1.12 so yeah its old. This is for a pioneer BDP-05FD or the BDP-51FD.
For some unknown reason I can not get this thing to burn to a disc on my computer. First the Iphone, now it won't burn, and blahhhh.
SO if anyone would have a disc with the firmware on it, I will pay the shipping for you to send it to me, seeing my computer will NOT let me do this for some unknown reason.
Post edited by cstmar01 on
  • superjunior
    superjunior Posts: 1,632
    edited March 2010
    cstmar01 wrote: »
    I think mine already has 1.38 but the update should be available to me from pio. I can try to burn it for you if you want.
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • cstmar01
    edited March 2010
    If you would be willing to do so that would be great. I just cant get my computer to do it for some reason, IDK. I called them to see if they could send me one and the lady told me no that they don't do that, so yep.
    Just let me know if you would be willing to do so for me and just PM if you would like. Like I said I'll pay for the shipping ect if you would like.
    Thanks!
    tonyb Posts: 33,072
    edited March 2010
    You do know if you call them,they'll send you a disk for free.
  • squeeb
    squeeb Posts: 426
    edited March 2010
    I have the disk from Pio. If you need it, I will ship it. If I remember right, I just went online and requested it and they shipped it. Just let me know.
    7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
    Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
    Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
  • cstmar01
    edited March 2010
    tonyb wrote: »
    I did call them and they told me they would not send it to me and I would have to either do it myself off the website or find a disk. That is what I was told.
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited March 2010
    When I got my Pio blu ray player they added a thumb drive in the box. Maybe try to download it to one and put it in the USB port. See if that helps.
    edited March 2010
    Does that Pioneer player have a USB port? I don't remember....I bought one, then I left for China, so I never set it up. I too was able to download and burn the version 1.38 firmware upgrade onto a CD from their site...no problem.
    Now the problem I did have was downloading the firmware upgrade for my Toshiba HD-DVD....no dice on that one!
    cnh
    Toolfan66 Posts: 18,059
    edited March 2010
    go to the website and request it from there, it will be like your purchasing it but there is no charge, I just got mine but have yet to use it.
  • cstmar01
    edited March 2010
    well I've now tried it a few different ways and no luck.
    I burned it on my computer as the ISO file and no luck. Tried my Gf's no luck. Tried different ways to extract the file no luck.
    I tried to copy it over to the USB thingy and no luck with the player, it just sat there. Every time I do the disc it tells me it can't read it, or just says data disc and won't download.
    I am starting to wonder if its possibly due to how old the firmware thats on it. its a 1.12 which is like when the player first came out, and I'm trying to do the .38 and didn't know if that would cause problems.
    I'll try and see if I can get the disc online. Normally I call. which I'm doing now (again) and I've been on hold for like 10 mins. blah took me long enough the first time to get through, guess we'll see if I get a different answer!
  • Pauly
    Pauly Posts: 4,519
    edited March 2010
    ISO File?
    Cant just burn those. Have to create as image. WIN 7 has it built in. If not use http://www.imgburn.com/
    Pauly
    Life without music would
  • squeeb
    squeeb Posts: 426
    edited March 2010
    cstar, pm me your address and I will mail you the disk. Think of it as you won my pioneer firmware update karma - congratulations. If you can get it burned before you get the disk - fine. If not, then you will have it in a few days.
  • cstmar01
    edited March 2010
    Pauly wrote: »
    ISO File?
    Pauly
    My gf's computer has win 7 and it still wasn't working when I burned it from there. I did try the software I had to do the image burn but I'll have to go back and try it with the stuff you recommend to see if I get any better results.
  • Pauly
    Pauly Posts: 4,519
    edited March 2010
    cstmar01 wrote: »
    WIN 7 has i built in but you have to pick Burn Using WIN 7 Disc Img Burner.
    Linky
    http://windowsteamblog.com/blogs/windowsexperience/archive/2009/04/13/burn-iso-images-natively-in-windows-7.aspx
    Good Luck
    Pauly
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2010
    That's the only negative I can think about the pioneer bdp's. Love my PS3, easy wireless downloads.
  • cstmar01
    edited March 2010
    well after being on hold for 20 mins and then again for 20 I will be getting a disc from them. Just may take forever but I will be getting the disc. Thanks for the help and in the meantime I'm still going to try and see if I can get one to burn on my system.
    Thank you!
