Help on PS3
doggie750
How to play music/ movies from my passport drive. It aint reading it and I hate to buy medial players such as the WD and ASUS. Please advice. I believe there's a way to make PS3 recognize the external drive.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
must be formatted in fat i believe and stored in appropriate folder structure.
The directories should look like:
/MUSIC
/PICTURE
/VIDEO -
I heard that FAT would be limited and NTFS would be the right route for this. Still surfing the net for answers .........
Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
PS3 as far as I know will ONLY recognize FAT32. Bruss' answer was exactly the way I understand it as well.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I really don't think Fat32 would be in any way limited. Most USB flash drives are formatted in Fat321 and I"ve never noticed any limitation with them. Just hook it up to your computer an do a fat32 format and then plug it in and see what happens. You got nothing to lose:)Testing
Testing
Testing -
ok so far I found this site and it's pretty helpful to those who are inline with meh. CHEERS.
http://hubpages.com/hub/How-To-Play-MKV-Files-On-Playstation-3Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
I think once you get a file over 4GB you start having issues.
It is far easier to run ps3MediaServer on a workstation and stream it to the ps3. You can even leave your external plugged in to the workstation with a NTFS formated partition. Not really wireless friendly though.. YMMV -
Okay, would work okay for music files was what I was thinking. The op will have to elaborate a little on the movies hes trying to access....Testing
Testing
Testing -
Yeah as far as the formatting and file structure ive never seen it read a external hanging off it any other way. -
I think you might be over thinking things. When I plug mine in (for music) go to the music option and find your hard drive... then hit TRIANGLE and select display all... the files should pop up. Same goes with video. Dont just hit X....
Hope this helps. -
grimmace19 wrote: »I think you might be over thinking things. When I plug mine in (for music) go to the music option and find your hard drive... then hit TRIANGLE and select display all... the files should pop up. Same goes with video. Dont just hit X....
Hope this helps.
@ Grimmace19: what video file format do you have? AVI?Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Will try it once I get home......THANKs BRUSS
is this the correct link...?
http://ps3mediaserver.blogspot.com/Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
I don't remember the correct link...this player is FREE from GOOGLE....so you can go to Google and find it! I use this as well and it works fine...no trouble with movies over 4 gig stored as ISO files on your hard drive. The important thing for film and video is that your wireless or internet access is FAST enough or else things will stutter!
I've got myself one terabyte waiting for me on my return from the Far East!
This is the correct link..
http://code.google.com/p/ps3mediaserver/
