TECHNICS SL-Qx300 QUARTZ DIRECT DRIVE TURNTABLE
snow
snow Posts: 4,358
Up for grabs is a TECHNICS SL-Qx300 QUARTZ DIRECT DRIVE TURNTABLE in near mint condition with original box and manual. I dont have any pics of the actual TT for sale at this time but I will get some up next week, this TT looks better than the one in the pics. In the meantime here are a few I borrowed from an Ebay sale. This would make a good starter TT for someone or for a spare in case your primary one goes in the shop. $50.00 + shipping. money order preferred
REGARDS SNOW
Post edited by snow on
    nooshinjohn Posts: 26,002
    edited February 2010
    a great way to try vinyl on the cheap. A nice table at a nice price.
    You need a seperate phono pre amp for this table or could I use a tape input on my receiver? Been 30 years since I had a table, you know that memory thing and age don't mix well.
  • snow
    snow Posts: 4,358
    Keiko wrote: »
    You'd need a phono pre, bro. Nice entry level table. Good luck with the sale, Snowman.
    Thanks for the good luck wishes and the answer for Tony. This is all part of an evil plot..... the way I see it is if I can get someone into Vinyl cheaply than GG will sell more LP's then the kids will benefit and everyone wins :D
    REGARDS SNOW
  • tonyr1
    tonyr1 Posts: 103
    I will take it Snow. PM sent
    Just bought some vinyl from George and I need a TT now.:)
  • snow
    snow Posts: 4,358
    tonyr1 wrote: »
    Ok Thanks for the sale.
    REGARDS SNOW
  • tonyr1
    tonyr1 Posts: 103
    edited April 2010
    waiting for snow to get back to me....maybe someone online now could help. took the 3 transport screws out and put the platter on. platter turns but the tonearm won't move over to the record. the tonearm clamp is not on and I don't see the transport protector for the tonearm on there.
    when I try the autostart the arm lifts up, moves slightly and just sits there. :confused: any ideas???
  • Motzart
    Motzart Posts: 1,075
    edited April 2010
    tonyr1 wrote: »
    I had the same unit YEARS ago....great TT BTW.
    Oh a adjuster in the back somewhere controls that I had that happen once.
    Don't quote me on this it's been a loooong time.
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  • snow
    snow Posts: 4,358
    edited April 2010
    Hi Tony I am not familar with that TT so I will be of little help but I will try to find out what the problem may be, you might also post a question in the Electronics area regarding this. If we cant get this problem solved I will send you your $$ back and you keep the TT :)
    REGARDS SNOW
  • snow
    snow Posts: 4,358
    edited April 2010
    Too late too edit but I posted a question regarding this problem in the Electronics area hopefully it will be an easy fix.
    REGARDS SNOW
  • Gempler
    Gempler Posts: 308
    edited April 2010
    tonyr1 wrote: »
    the platter has a rubber pad with two cut outs each with little sensors that determine the size of the disc that is on the platter (45 or 33). if there is no disc on the platter then the autostart function will not operate. if there is a disc and it is still misbehaving i would look at the alignment of the rubber pad on the platter or remove the platter entirely and look at it from the underside. perhaps the platter is not correctly installed.
  • Gempler
    Gempler Posts: 308
    edited April 2010
    this thread holds a wealth of information on the sl-qx300 including how to make some adjustments that might solve your problem...
    http://www.vinylengine.com/phpBB2/viewtopic.php?t=14965
