Should a subwoofer run dead silent when it's turned on?
When a subwoofers power is turned on should they run dead silent? My last 2 subs have had a slight buzz coming from them. Is this just the current running through it or is it something else? Like I said it's been the current and past sub and each sub was used in a different apartment. I'm just curious.
Post edited by Underworld54 on
  • bevo
    bevo Posts: 306
    edited February 2010
    Mine is dead silent.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
  • TouchOfEvil
    TouchOfEvil Posts: 967
    Unless you have grounding issues or getting noise from your cables it should be silent.
    All mine are.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • Knucklehead
    Knucklehead Posts: 3,602
    Yep, my sub is quiet as a mouse......I will say when I was using a basic sub cable I did have a quiet hum at times, once I upgraded to a quality Monoprice cable hum was non-exsistant.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • packetjones
    packetjones Posts: 1,059
    Yes it should be silent. Chances are you have a ground loop issue or maybe a bad cable. Are you using the same cable on both of these subs. Have you tried plugging it into a different outlet? Does it hum when it is not connected to the receiver at all?
    Just some things to look into.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • Underworld54
    Underworld54 Posts: 43
    With the cable unattached to it, it still buzzes. To test it I unplugged everything from it and turned it on. I have yet to try it in a different outlet. The sub seems to perform well so i'm not sure what's up. Is there something I can try to get the buzz to go away? I hear cheater plugs are a bad idea.
  • Underworld54
    Tried a different outlet and it still buzzes.....hmmmm. :confused:
  • zarrdoss
    zarrdoss Posts: 2,562
    ground loop isolator
  • Huck344
    Huck344 Posts: 453
    edited March 2010
    zarrdoss wrote: »
    Correct me if I'm wrong, but if the sub is buzzing when nothing is connected to it, is he experiencing an actual ground loop problem or another issue? My understanding is that if the sub buzzes when nothing is connected there is no actual "loop" and it could be a sub amp issue or something else.
    By the way Underworld, what kind of sub are you running?
  • Underworld54
    edited March 2010
    Huck344 wrote: »
    I am running a Accoustic Audio HD Sub10.
  • zarrdoss
    edited March 2010
    try another outlet in another room with nothing connected. I am guilty of using a cheater plug to get rid of the ground to remedy the problem, not the best solution but was at my wits end.
  • Underworld54
    edited March 2010
    zarrdoss wrote: »
    I tried another room last night and it still buzzed at the same level as it has in the previous outlet it was plugged into.
  • zarrdoss
    edited March 2010
    try the cheater just for s**ts and grins.
  • Underworld54
    edited March 2010
    zarrdoss wrote: »
    Tried that already too...:)
    pitdogg2 Posts: 27,549
    edited March 2010
    The different outlet could still be on the same circuit and could be the reason you still have a buzz. I had that problem with a buzz found out it was the old fridge i kept all the adult beverages and soda pop in it was on the same circuit. The fridge was going bad and i had thought it was as it just didn't feel as cold as it used to. I got a new fridge and then ran a dedicated circuit for my audio gear. 20amp breaker on the top of the circuit breaker box two new dedicated ground outlets and some 12ga. wire to the breaker so nothing in the house shares the same breaker. works wonders
    I have two subs in my HT neither one buzz dead quite until they need to make big booms:)
  • zarrdoss
    edited March 2010
    same result? if so it could be something in your sub is bad, or something in your wiring in your apartment such as low or high voltage, noise, etc take it to a friends house and try their electrical. Apartments usually are not known for great wiring or constant voltage.
  • Underworld54
    edited March 2010
    zarrdoss wrote: »
    Yeah I have all my gear hooked up through an APC H15 and the power stays between 117 and 121. I haven't seen it drop below that.
  • zarrdoss
    edited March 2010
    well it would seem to be an issue with your sub itself then or maybe electrical noise
  • Underworld54
    edited March 2010
    zarrdoss wrote: »
    Yeah looking so. I don't really have the funds for a new subwoofer so I may have to hold off for a while. I could find someone to install a new Amp plate in the subwoofer, you can get a Dayton one from parts express for a little over $100.
    Oh by the way, I hope I didn't come off as blowing off your suggestions. All of them were very helpful and I appreciate each one. Thanks for taking the time out and helping me with the problem
  • quadzilla
    quadzilla Posts: 1,543
    edited March 2010
    I had a sub that did that. I had to replace the caps in the power supply to get it quite. Now it's dead silent again.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • zarrdoss
    edited March 2010
    No offense taken. I would do this.
    http://forum.blu-ray.com/subwoofers/85212-official-acoustic-audio-subwoofer-owners-thread-160.html
    I am using that same amp on a 15" kicker comp sealed sub. I have also used a Bash 300 watt amp from PE and would recommend.
    Attachment not found.
  • Ranger0912
    Ranger0912 Posts: 50
    edited March 2010
    Should be quiet. As noted by a few others, grounding issues are usually the most common culprit when it comes to speaker hum.
    McIntosh MA-7000 Integrated
    Cambridge Audio Azur 840C CD
    B&W 805s
    Logitech Transporter Wireless Link
    Mac Mini Music Server
    Furman Elite Power Conditioning
    Signal Cable, Magic Power Cables
    Signal Cable, Silver Resolution Balanced Interconnects
  • Conradicles
    Conradicles Posts: 6,396
    edited March 2010
    zarrdoss...since you have used both plate amps I am looking to purchase, would you recommend the Bash or the Dayton?
    zarrdoss wrote: »
