Remote control for hidden components
dsc
I have my stuff set up in a corner cabinet and I am also at the point where I feel audio components should be heard and not seen.
So, I don't want to have to open the bottom doors of the cabinet where my Yamaha Rxv1200 is housed.
Does anyone make a relay device that would allow me to have a receiver for my Yamaha remote in the upper part of the cabinet (where the monitor is housed) that would then relay my remote's commands to the hidden receiver?
Someone must make something like this because my Samsung satellite receiver came with a little cable that has a transmitter on the end of a cabled plug. You attach the transmitter over the "eye" on your VCR and plug the cable into the Samsung and the Samsung remote operates your hidden VCR.
TIA.
Regards,
Dewey
TIA.
Regards,
Dewey
Dewey Clark, owner
Historic Timkeepers, Inc
Full restoration services ofr precision timekeepers
http://www.historictimekeepers.com
Post edited by dsc on
yes radio shack, remote extenders.. or remote pyramids is what they have at RS stores, works great and can be used up to 100 feet away from unitMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I had posted this request to several other groups and got THE answer.
I had looked at the Recoton/Radio Shack thing but the second unit still requires line of site to your equipment. Some of us have our equipment completely out of view and in tight spaces.
There are two manufactures of IR repeater systems where an emitter is taped over the eye of your equipment's IR sensor; Xantech and Channel Plus. Xantech puts together a kit that includes four emitters (for you equipment) for about $100.
Here is the link http://www.xantech.com/products/p_folder/p_291kit.htm
This is just what I need so that I can operate my system while keeping the cabinet doors closed.Dewey Clark, owner
http://www.historictimekeepers.com -
The RS extender will work without direct line of sight. I put the RS pyramid on top of my reciever and it bounces the signal off the closed door to the front of the reciever. It may take some experimenting with the position but the single RS extenter currently controlls all 6 components in a small closet 30 feet from the listening room. Cheap solution to your problem.
dsc,
I've used a xantech hard-wire, IR repeater for over a decade as my equipment is in a separate room next to my listening area. They make a very simple and reliable unit, and it's easy to add on added flashers - just splice them in parallel with each other.
Very good choice IMO...More later,
Tour...
Vox Copuli
