Replaced FXi30's with FX500...need opinion....
dl090465
As the title said, I changed the surround speakers I Have in Room 2 which is in my sig....I haven't edited my sig yet...
My question is, do the older FX500 match the FXi30's as far as timbre??? So far I like the way they sound, the highs could be a little better......
Here is a stupid question, are the tweeters the same?? would it help to swap the tweeters if they fit??
Thanks,
Dave
Thanks,
Dave
Room 1:
ONKYO TX-SR608
Polk Complete RT 5000 System
Polk RT3000p's Front
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk RT2000's Front Someone Please Sell Me Some RT3000 so I can have a second RT5000 setup !!!!
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear
Post edited by dl090465 on
If I'm not mistaken, the main difference between the FX500's and the FXi series was the mid-range drivers. I don't think they changed the tweeters. Not sure how the x-overs might make a difference in your case. Have you connected both of them up to just a two channel system and played music through them to see if they really do sound that much different?____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050 -
don't really have any two channel set ups to use....Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
replace your mains with them temporarily____________________________________________________________
finally got around to doing that, the FX500's are awesome, much improved over the FXi30's....Thanks for the advice..Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear
