Any laptop technitions?
warlocks1
I have a Gateway laptop with a power jack issue. I have to jiggle the power chord over and over to get it to charge. I did some research and it sounds like replacement of the power jack can be difficult and result in total destruction of the motherboard. I was wondering if anyone would be willing to repair for decent price?
Thanks, Jeff
Thanks, Jeff
Post edited by warlocks1 on
that is a pita alright. Sounds like the motherboard jack is loose? Or is there a pin inside the little block that is loose? Replacing it is a beatch.
Look for some tutes online at notebookforums if you're handy with disassembling.
If you can get the case open to that point, sometimes you can hotglue it down. -
Thanks, Jeff
This might be a stupid question but are you sure it isnt the power cord itself?
ShawnShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
I had the exact same issue with a Compaq X1000 a couple of years ago. It is a condition in which the soldered female power port on the motherboard came loose because of repeated push-pull of the power jack. I took a part the laptop completely, removed the mobo, removed the old power port and put a new one (OEM) I got over the fleabay. It works well for over 3 months, and then it started doing it again. When it happened again, I decided it was time to get a new one and put it out off its misery. Looking back, I feel it wasn't a worthwhile effort to do this. The laptop had served me well since 2004 when it failed in 2008.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
what model / year Gateway ?
I have tried 3 different power cords. All do the same. I have to close the laptop, plug in the adapter, wrap the cord around the laptop and jiggle the cable until I find the right spot.
The laptop is a Gateway MT6841.
Thanks for the replies. -
Shawn
Exactly what I was going to ask.
I have a Gateway latop, that I am on now, that did the samething. It was the cord itself. Not the jack. I actually cut away the insulation on the plug, resoldered it and it worked fine. Used it until I got a new one.--Gary--
As others have stated, the resolution would be to replace the mobo. Way back when I use to do this stuff, it was only worthwhile if the unit was under warranty because the cost was so high. Unfortunately, at this point, you're looking at a new laptop purchase in the near future. If you really like your Gateway, call the company to find out what it'll cost to get it fixed.
Good luck -
The mobo itself on ebay is about 200 not counting labor. The DC socket is 6 bucks, not counting labor.
You can buy a good laptop new for 400, or a great one slightly used.To replace the board using a local shop, prolly 350.
And woilla woilla washington, what do you know, this guy in Illinois says he will replace the jack for 98 plus shipping.
Laptop Repair -
I found a place in my area that will do it for $80.00. I will probably give it a shot. Thanks for everyone's help. Long live Polk Audio forum!
Laptop Repair
I would stay away from "good laptops" that are $400...:)Testing
Testing
Testing -
i have seen this problem on quite a few laptops. Including my fathers and my sisters the first thing you can try doing is buy a new power cord and adapter. If that does not work I would send it in for repair if it is under warranty. If it is not I would not recommend dropping like 300 bucks for a new MB to fix the problem. sometimes you can re solder the power port back onto the board but you have to know what your doing.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I do these types of repairs on laptops all the time. To pay someone to do it does cost a bit, as it's quite labor intensive on most laptops just to get them apart to the point that you can access the jack. I usually charge $50-$75, also depending on the price of the jack itself.Ludicrous gibs!
