SDA2A RDO198 Upgrade??
JPSmario
I'm a new SDA owner; got a fairly clean pair and was lucky to have a Polk expert friend help fix the problems I didn't know I was buying :mad:
I've been getting ear fatigue much sooner with these than my old speakers (B&W 602 S2), and my friend tells me it's probably the SL2000's. We had listened to both the SL2000's and the RDO194's in a couple pair of his Polk's and he remeber's me preferring the replacements.
After looking through several threads, there seems to be a consensus that the RDO198's are cleaner and clearer than the RDO194's. But I'm not clear on whether there's a clear mod plan for upgrading the SDA2A's with the RDO198's.
Is there a plan that most people have had success with?
Thanks!
Thanks!
Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
Post edited by JPSmario on
"Nope" you have to use the RDO-194's they are the replacement for the SL2000's
Welcome to the club by the way..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
You'll have to go with the 194's. Don't worry though, you'll be more than happy with them. They're a big improvement.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
WELCOME TO CLUB POLK!
That's an improvement I'm hoping to hear myself on my 'return'!
Have you considered upgrading the crossovers with better caps and resistors? I think that you will be pleased should you perform the upgrade and install the RDO 194's.JC approves....he told me so. (F-1 nut)
Thanks, everyone for your comments and advice. I have a pair of RDO194's on the way.
I looked through a couple of the related threads listed below; was that a good parts list from Reagan on 11-7-09? no offense, just want to verify it before spending the money. Other than mic and speaker cable ends, I haven't picked up a soldering iron in seriousness since I assembled 2 Dynakits almost 40 years ago. Does the x-over upgrade have any tricky steps?
Thanks!Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's -
Wait a sec, you can upgrade your crossovers to use the RD0198-1 tweeters. You'll have remove the 2.7 ohm resistor in series with the 0.4mH inductor. Then follow the documented upgrade for the 2B TL, which simply adds a 5.8uF cap in parallel to the remaining 2.7 ohm resistor.Political Correctness'.........defined
President of Club Polk -
JPSmario-- I am curious,, do you have the p/b or the b/b interconnect?JC approves....he told me so. (F-1 nut)
If he has the SDA 2A B/b,, it can be upgraded to the tl?JC approves....he told me so. (F-1 nut)
Sure you can it's just a matter of some crossover rework."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
I'd love to have a pair of MK IIIs if you have a couple of extras thanks in advanceYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
I have the b/b IC.Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
If you can solder,,you can do what is necessary to the crossovers,, schematics are posted here,,and there are plenty of folks willing to help.Good luck,and keep us posted.JC approves....he told me so. (F-1 nut)
george daniel wrote: »If he has the SDA 2A B/b,, it can be upgraded to the tl?
Yes.Political Correctness'.........defined
SVS SB16 X2
Yes.
wow! for some reason I thought this could only be done with the 2B's. So I am assuming the MW's also have to be replaced to make it a TL model or can they stay 6510's?
Also, is it worth it if I have already put RDO-194's in? Would it make more sense to just do the xovers and keep them moded 2A's? -
I too, was under the impression about the 2B's being the only candidate for the tl upgrade,, so,, in the very near future,, I am going to be upgrading,helping another polkie perform the mod.I'll let you know how it turns out,as it appears to be a fairly easy task,,I'll post more when I know a little more about the specific speakers.JC approves....he told me so. (F-1 nut)
Wait...what?
I've asked on here before if 2A's could be TL'd, and my question was met with a resounding "NO".
Is there any reason that a TL'd 2B would sound better than a TL'd 2A? I know they used different MW's.
Also...+1 to chandler's question. I've got some 2A's with 194's...would it be worth it to upgrade to 198's? I've been contemplating whether I want to upgrade the XO's in my 2A's, or hold off for a pair of 1C's. If I decide to upgrade the XO's in my 2A's, it probably wouldn't be much extra work to TL them really.The nirvana inducer-
The 2BTL mod is the only "officially sanctioned" mod in the SDA2 series because the crossover is the same as the CRS+ model that that mod was originally done on. Since the mod only affects the tweeter, it should be able to be done on the 2A as well. No mids would need to be changed. It is to be done at your own risk. Since this is not a change that was signed off on by Polk, it does approach frankenpolk status. And Jesse, I think that 2.7 ohm in line with the inductor would have to stay, otherwise the balance between the mids and tweeter would be off.
As to whether it's worth it to change from 194s, only a person who has had his ears on them both ways could tell you that, and that isn't me."The secret of happiness is freedom. The secret of freedom is courage." Thucydides -
Well, it sounds like it "could" be done but I am thinking I might just try the xo mod since I already have the 194's and be happy with that... They really are good speakers. I like the TL's but this might be just fine unless Polk suggest they could be better.
Just my opinion but I could be wrong and those with more experience may want to chime in. -
Disc Jockey wrote: »Since the mod only affects the tweeter, it should be able to be done on the 2A as well. No mids would need to be changed.
Yep.And Jesse, I think that 2.7 ohm in line with the inductor would have to stay, otherwise the balance between the mids and tweeter would be off.
Can you explain why you think that? I'm not disagreeing with you as you may be correct, just curious.As to whether it's worth it to change from 194s, only a person who has had his ears on them both ways could tell you that, and that isn't me.
I have on the CRS+ and 2B. The RD0198-1 is a major improvement, IMO.Political Correctness'.........defined
Well, here's my take on it: The purpose of the inductor there is to draw the low frequencies down to the mids. The resistor's purpose is to limit current, and therefore output of the mids, to achieve proper balance between the tweeter and MWs. The TL mod was designed to just address the tendency of the 198 to roll off at higher frequencies without affecting the rest of the crossover. I believe by taking out that resistor, you would be affecting the rest of the crossover balance and the mids are going to run hot."The secret of happiness is freedom. The secret of freedom is courage." Thucydides -
It's my understanding that a resistor in that position will affect the driver's Q and will steepen the roll off at the crossover frequency. I'm assuming that the RD0-194 and 198 behave similarly at low frequencies, so it's possible that this resistor may not be doing any harm if left in place during the TL mod. The only way to know is to model it with the appropriate software, measure it, or maybe get some feedback from Polk.
I was going to attempt to model this in LspCAD, but I just discovered that I lost all my saved work and have more important things to worry about at the moment."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
That is my understanding."The secret of happiness is freedom. The secret of freedom is courage." Thucydides -
Disc Jockey wrote: »Well, here's my take on it: The purpose of the inductor there is to draw the low frequencies down to the mids. The resistor's purpose is to limit current, and therefore output of the mids, to achieve proper balance between the tweeter and MWs. The TL mod was designed to just address the tendency of the 198 to roll off at higher frequencies without affecting the rest of the crossover. I believe by taking out that resistor, you would be affecting the rest of the crossover balance and the mids are going to run hot.
Hmmmm...entirely possible. Perhaps someone willing to mod their 2A's to use the RD0198-1 would be willing to let us know what happens with the resistor in and out........or we can wait for Face to quit fooling around.Political Correctness'.........defined
Try it Curt!!! If you don't feel comfortable (hehe) with soldering, I'll do it for free.
Thanks!
Welcome to Club Polk. F1 hit it on the head.
Study the schematics for the SDA 2A and SDA 2B posted here and you will see what F1 is describing . . . http://www.polkaudio.com/forums/showthread.php?t=55888
I've owned SDA 2B's since 1987 and there is no comparison when you upgrade the crossover to accommodate the RDO-198. Results with the 194's will be good, with the 198's, superlative.
I can't speak to the removal of 2.7 resistor (the one in series with the .4 inductor) as the 2B circuit does not have that configuration, but the 6.5" drivers in your 2A's are all MW6510's (where the 2B uses 1 each MW6503 & MW6511) but my guess is leaving the "extra" 2.7 is probably OK. I'm also guessing the extra 2.7 may be there more to match characteristics of the the 6.5 mid drivers than for the tweeter.
As posted prior, only experimenting both ways would allow you to be sure, but leaving the extra 2.7, listening, and removing later would be a logical path.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Do your SDA's have the side by side tweeters?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Hi Ben! You doin' OK?
There should be one tweeter per cabinet if they are SDA 2A's -- http://www.polkaudio.com/forums/attachment.php?attachmentid=26673&d=1186345413
(real similar to 2B's http://www.polkaudio.com/forums/attachment.php?attachmentid=26674&d=1186345413)VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
if Ben's question is for me, no, I have single SL2000's.Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
Just making sure. No pics;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
